1.2 bar tune question
#46
if i were you and you dont have a TRUSTED tech(?) i would PM "Kevin @ umw" here who is very giving of his time and expertise and does this for a living. you might also want to consider purchasing a "new" tune from him as you won't do better is the common wisdom here ( and in the real world lol. )
problem is, until you do a pressure test of your vac system? you cant properly and/or definitively identify leaks, though most find them upon pressure testing at the turbo's.
i cant help more, but you def need some pro help and again, i'd reach out to Kevin. he could certainly help to pinpoint a cpl things it could be. good luck with it as it aint quite right if the boost gauge maxes out at ( yes sorry.. ) .4.
again,.. GL w it.
#48
