Brakes
Brakes
So in 02 my C4S brakes seemed astonishing.
Now my 04TT is meh. AFAIK they have the same system.
Brakes are to spec.
Has braking technology got that much better in the intervening time?
If so what's the favored reversible fix that will leave me two kidneys.
Brakes are to spec.
Have you had the brake fluid flushed and bled recently, within 2 years?
I put on a set of GT3 calipers and some RS-29 pads this evening after running Kevins turbos at the track for the first time today. The difference bedding them in is immediately noticeable and I can't wait to try them at speed. Going up to 6 piston 350 is an easy swap that is reversible.
