996 Turbo Forum 1999-2005
Help! Remove rear right side drive shaft?
Old 04-03-2016 | 07:48 PM
Kenneth_asbjorns's Avatar
Kenneth_asbjorns
4th Gear
Default Help! Remove rear right side drive shaft?
Hi!
Having some problems to remove rear right drive shaft on my 996 turbo, 2001. I'm Almost finished, but can't get all the space i need to get it out. Any tips or DIY?
Old 04-03-2016 | 10:35 PM
32krazy!'s Avatar
32krazy!
try lowering the motor and trans a few inches
Old 04-04-2016 | 03:05 AM
993GT's Avatar
993GT
remove inboard toe-link and inner&.mid LCA connection...mark eccentric before
Old 04-04-2016 | 06:20 PM
Kenneth_asbjorns
4th Gear
Shaft is out! Is it possible to buy 3party shaft or do I have to spend a fortune at Porsche?
Old 04-04-2016 | 06:49 PM
vogz's Avatar
vogz
What's wrong with it? A good driveline shop could probably re-build it for much cheaper than a new one. The only 3rd party options are more expensive (and stronger) than OEM.
Old 04-04-2016 | 06:57 PM
Kenneth_asbjorns
4th Gear
The joint that is connected to the weheel side is bad.
Old 04-04-2016 | 07:38 PM
vogz's Avatar
vogz
Outer CV, got it. Did the boot tear and leak out grease or is it just making noise?
I would find a local shop that specializes in cv repair before shelling out the cash for a whole new unit. Could save you a significant cash.
Old 04-05-2016 | 04:27 AM
Kenneth_asbjorns
4th Gear
I was told at my local porsche Center that I had to replace the shaft because it's not possible to get a hold of loose outer cv joints to replace..
So I bought a used shaft, but when i check the part before installing, I think this shaft has the same problem..
What is the correct way to check if a rear shaft outer joint is bad when Not installed on the car?
