RSS Engine mount install impressions
Those RSS mounts look great.
What is that Aluminum part the mount is sitting on? Is that what the factory mounts sit on?
Did this take care of your funny wiggle we were talking about last week?
I put Euro RS Mounts on my 964, since my original ones were shot. Not as good looking as the RSS mounts. I did a lot of other mods at the same time so not sure what the impact of these mounts were.
Ceby
Ceby
Originally Posted by Richard.
I just found my 18 mm socket, very unusual size
Make sure the square pegs are lined up, I had to turn mine with a wrench to get it right.
Only just received them today, I was in preparation and put a stripe decal on the TT last weekend which was hard work & as I'm a perfectionist it took 4 hours. Will get the RSS items on over Easter
In my standard nothing says success like excess I picked up the RSS full solids lol. Definitely see some vibration periodically through the Rev range and you start to question the engine sounds at idle (not because they're loud but because the engine has so much "character"). Fortunately they don't seem that loud thanks to the FabSpeed exhaust covering it up. Have my first DE with them end of April should be interesting. The car move so much more as one now even when just doing some spirited driving.
Some form of mounts is a must for the 996.
Ok so RSS mounts on, it took me circa 3 hours but probably didn't help that I didn't start until 10.30 pm when the family had gone to bed. I did it without removing the Y pipe but the drivers side was truly difficult with my larger connecting pipe from my AWE Intercoolers and the 3 inch Y pipe, which only have a very short Silicon connecting hose. The other side was easy.
I now need to lower the exhaust tips a little as you will see from the pic.
The RSS mounts do give more of a mechanical connection with the car.
I also post a pic of the stripe I added last weekend which won't be to all your tastes.
paddlefoot64 (06-07-2020)
Judging by the change in height of your exhaust tips you needed new engines mount.
Good work.
Good work.
Agree with everybody - it's a great mod. Did mine a month ago. The only downside for me is some interior buzzing at 3100 RPM which is where I spend a lot of time on the highway, so need to track it down. These mounts along with a GT3 rear sway bar have absolutely transformed my 997 C2 from a GT car to a sports car.
Semi Solid Engine Mount NHV Buzz
Generally speaking, performance engine mounts will increase NHV (some designs more than others) vs. OE mounts . I suspect the noted buzz around the 3k RPM Range may be correlated with Porsche's Vario Cam System transitioning between operational modes/cam profiles. By design semi solid performance mounts will transmit more of the engines NHV vs. OE liquid filled mounts designed to mask or dampen engine harmonics or buzz.
wevo's semis ( by example) contribute NO added NVH to the cabin while delivering instant feedback and tautness to shifting esp during cornering. slop is GONE. that, and a new 997 t-mount. covering all of the the 3 points of engagement of the motor to all else. kinda important. ya think?!
Good evening everyone! I finally got some time to install the RSS engine mounts that I purchased from Sharkwerks. This was the first time I have dealt with them for my Porsche, and it certainly will not be the last! Alex did an excellent job getting these shipped out quickly, and they arrived in perfect condition.
The install was straight forward and only took about an hour of actual work. Once I finally figured out that I lost my 18mm deepwell socket, and I had to go to the store and buy one (about par for the course when working on cars .) The only issue I had was for some reason I didnt get the engine jacked up high enough. The square part on the bottom of the new mount was not seating down in the cutout to stop it from rotating when tightening the 18mm nut on the underside of the mount. Once I got that figured out the rest was a breeze.
Impressions
I have a MKIV VW GTI VR6 with a TON of mods, and some 034 Engine mounts. Those have way more NVH than these mounts do by a far margin. Since I am used to performance mounts, the tiny added NVH on the RSS is a fantastic trade for the amount of feel you get. Shifting is much crisper, and is immediately noticable if you heel toe. Throttle response is much improved and damn near immediate on throttle tip in. I even felt the stability in the cornering which was my most sought after attribute. Why the car does not come from the factory like this I will never know. I will update this thread with more feedback once my AutoX season starts up. I cannot wait to try these out on the track, and run them through their paces.
I can attest to the great things others have said about these mounts. It is without a doubt the best $400 you will spend on this car! Just buy them, install them yourself, and enjoy. I attached some pics below of the parts, install, and my car with my uncles 454 SS 70 Chevelle.
Impressions
