996 Turbo Forum 1999-2005
Brake pad service
Old 03-12-2016 | 08:13 PM
Freddie Two Bs's Avatar
Freddie Two Bs
Default Brake pad service
When replacing the brake pads, is it mandatory to replace the shims and sensors, too?
Old 03-12-2016 | 08:19 PM
AtlantaPerimeter's Avatar
AtlantaPerimeter
Former Vendor
It will be highly unlikely that you are able to save the sensors. We replace the shims also.
Old 03-12-2016 | 08:38 PM
Carlo_Carrera's Avatar
Carlo_Carrera
Because track use I go through a lot of pads. In the past six years I have replaced one sensor. The rest of the sensors and and shims are original.
Old 03-12-2016 | 08:40 PM
Tim Wasmer's Avatar
Tim Wasmer
I have never replaced a sensor. But I have changed my pads before the warning comes on.
Old 03-12-2016 | 08:44 PM
Freddie Two Bs
Thanks, that's what I thought. I brought the car in to have the pads replaced with new oem ones, I've been presented a bill with six line items. I'm too embarassed to say how much.
Old 03-12-2016 | 09:19 PM
Carlo_Carrera
It is standard operating procedure for a licensed shop to do new sensors and shims with new pads. Most DIYers will reuse sensors and shims.
Don't feel too bad. Because I use expensive track pads I probably paid four times your pad replacement bill in just pads last year. It is a crazy hobby.
Old 03-12-2016 | 11:23 PM
Turbodan's Avatar
Turbodan
note aftermarket sensors are about $3 each. I just tie mine off and zip tie behind disks when I put the track pads in in spring. why replace the shims?
Brooklyn which pads did you go with?
Old 03-12-2016 | 11:28 PM
AtlantaPerimeter
Former Vendor
Because if you leave the old ones in too long, they rust into the piston and are extremely difficult to remove.
Old 03-12-2016 | 11:30 PM
juanbenae's Avatar
juanbenae
shops of any type will not turn rotors any longer either due to liability reasons even if they remain with in spec. that's why the "$39.99 an axle" coupons you see from time to time always make me chuckle.
I have not done the pads on my 6t yet, but when placing pads on my old SC racecar it always steamed me the pads were more expensive than rotors and lasted half as long.... im yet to get familiar with the new car's pad & rotors will set ya back....
Old 03-12-2016 | 11:52 PM
Freddie Two Bs
Just stock oem pads.
Old 03-13-2016 | 12:52 PM
Carlo_Carrera
Are the rear shims on the standard Turbo 30mm, or 28mm?
Old 03-14-2016 | 10:55 AM
sanyata's Avatar
sanyata
I was in a shop a couple weeks ago that had a machine that was turning a rotor while still on the car! Albeit wasn't a high end shop I'd never seen or heard of a machine like that. The tech told me it takes just as long or longer to set it up as it does just to pull the rotor.
Old 03-14-2016 | 06:36 PM
Tim Wasmer's Avatar
Tim Wasmer
Our Chevy shop turns rotors all the time. They did the ones om my 4S with no issues whatsoever.
Old 03-14-2016 | 06:49 PM
Fishey's Avatar
Fishey
Never turn rotors basically the pad is done then the rotor is done. Always a new pad sensor and most of the time shims unless using certain brake pads.
Old 03-14-2016 | 10:35 PM
Kevinmacd's Avatar
Kevinmacd
I thought turning drilled rotors is a no no!
