For anyone with pinned coolant lines.
POC here in SoCal has this in their GCRs Page 20. welded, pinned, or water wetter.
https://porscheclubracing.org/wp-con...f-11-29-15.pdf
Cup car components are timed out and replaced and those cars do not see the heat cycles the street cars do. Fact.
thanks for the link.
Good point on the time-outs as well.
Goodstuff!
I researched and debated A LOT before making my decision, also talked with a number of my good friends who are serious fab/welders, and one who is also the chief mechanic for a cargo jet liner. They all were concerned about porosity and HAZ/embrittlement issues long-term, and strongly suggested the pinning; done deal. If they were to do it, inserts like BBi's would be the way to go.
My decision was solely on what I/my connections thought was the best solution long-term, not cost(near free for me anyways) or effort...in 10/20/50 years, if a fitting fails due to stress or corrosion, I can pull it out and install a new one.
I am not saying people who have welded pipe WILL experience these issues, but they were concerns I preferred to avoid.
Cheers,
Rob
Cheers,
Rob
I believe it is a national PCA rule that all 7GT3s and 6gt3s and turbos be pinned, welded or water wetter. I could be wrong but I know that is the rule for my region, and it has been like that for about 2 years now. Regarding cup cars, I believe most of the races require water wetter in the rules.
I ran water wetter last season and switched back to antifreeze in the fall.
+1, and regarding Cup cars it does make sense for them to run water +WW
So far on the Cup thread, 2 guys with engines at PMNA for rebuild, both having them re-glued as per PMNA..
Specifically, for non-failed connections, to add a fillet of marine JB weld at the base of the pipe/casting interface much like one would do with a weld. This is instead of pinning.
Pinning, does not in itself prevent a failure. It just prevents a catastrophic failure. The original glue/seal can still fail from which point a pinning fitting will weep.
Theoretically, a fillet of JB weld will hold the pipe pretty darn well and add to the seal.
Anyone had experience doing it this way?
I've heard this from other outside sources as well, though rarely discussed on these forums.
I'm pinning mine while the engine is out and figure if it ever starts leaking that I'll weld it. Under 20k on my engine and don't feel it's necessary, just want to prevent a big dump at the track. they may hold for a long time and I'd just be throwing more $ at it now versus another time when the water pump and othe raccessories are off.
