Grind / lock out of 2nd on downshift
Worrying issue with my new baby. Today as I was driving at a moderate pace I went to downshift from 3rd to second, heard a horrible grinding noise and didn't manage to put the gear in. As it was grinding it felt like the shifter was 'bouncing' against something and clearly I didn't want to force it. Tried again, same thing.
Tried again at very low RPM, with a gentle, two-phase shifting motion, no issue.
Also no problems upshifting 1st to 2nd. Transmission fluid was changed as part of the post-PPI service, the shop didn't report seeing any pieces of metal floating, but then I can't say for sure they even looked.
Thoughts?
Thoughts?
No doubt, but nonetheless I'm hoping to hear some thoughts from the experts, particularly since the car has gone through a PPI and tranny fluid change less than 100 miles ago.
Is the clutch master cylinder reservoir overflowing? A telltale sign is fluid residue under the reservoir and on the plastic shroud! I had an issue where the reservoir was leaking due to the slave cylinder check valve. In actuality the slave was going and effected the release of the clutch. Did strange things to the clutch release and engagement height!
Just to complete Kevin explanation and answer your question. The clutch reservoir is under the front hood (bonnet) just in front of the driver side, under a black plastic cover, held with two screws....
Many thanks, I'll take a look
stock shifter and cables? sounds like you just missed the gear if you were able to slow down the motion and it went in without issue. factory shifter is crap and cables may need a bit of adjusting
Thoughts?
Thoughts?
At what engine RPMs were you trying to downshift from 3rd to 2nd? IIRC the owners manual advises against downshifting above 2K RPMs. (While I don't strictly adhere to this I seldom downshift from very high RPMs and when I do of course I rev match.)
Are you sure the shop knows these cars and used the right fluid and filled the transmission correctly?
A "test" of sorts... With the engine/drivetrain up to temperature and the car on level ground with the engine at idle you should be able to push the clutch pedal down and then select any gear without any difficultly. If you have any problems, notice any difference in say shifting from 3rd to 2nd compared to shifting from 2nd to 1st or from 4th to 3rd there can be a mechanical problem. There could be a linkage or linkage adjustment problem, but to eliminate this you would need the services of an experienced Porsche tech.
Sure it wasn't driver error? Unfamiliar car and all that?
Amyhow, I'll bring the car in soon, so hopefully we'll find out.
I am a very mediocre driver without question, but not sure that's the issue here. Can't remember the RPMs, but it wasn't like downshifting for turn 10a at Road A...
The shop has a couple of recommendations here on rennlist. Although they managed not to replicate the power steering reservoir whine, which took me the whole of 5 mins when I picked up the car
Everhything shifts smoothly in the test above, except maybe a slight notchiness from 1st to 2nd. The shifter has quite a bit of play, I don't like the feel of it at all.
My 2003 Turbo didn't shift all that well then the shifter broke at around 30K miles. The tech installed a 997 shifter which felt much tighter and shifting improved. 100K miles later and the shifter still feels tight.
However, I am not recommending you throw a new shifter at the symptom. Let the shop advise you.
all of this reads like the a graphic explanation of why a change of ALL fluids when buying these at their age becomes so important. this could be old trans fluid. hopefully it isn't a synchro issue as that would hurt $. if you don't know when the trans oil was last changed? I would change it asap
