996 Turbo Forum 1999-2005
Oil change... Best filters etc
Old 03-23-2015, 04:14 PM
  #46
Medevack1
Medevack1's Avatar
Originally Posted by Dock
I change my oil every two years.
I change mine 3-4 times a Yr lol This is my DD....
Old 03-23-2015, 04:19 PM
  #47
Dock
Dock's Avatar
Yea, mine is not a daily driver. I bought it new in 2002 and have averaged less than 3400 miles/year since.
Old 03-23-2015, 04:27 PM
  #48
rmc1148
rmc1148's Avatar
I felt bad and changed the oil in my f350 today as its been three years but less then 4000 miles.
Old 03-24-2015, 12:35 AM
  #49
dprantl
dprantl's Avatar
Everyone should just make sure they change their engine oil more than once every 84k miles...
Dan
Old 03-24-2015, 01:03 AM
  #50
rmc1148
rmc1148's Avatar
Audis suffer enough from sludge issues lol.
Old 09-24-2020, 01:55 PM
  #51
matty1
matty1's Avatar
I'm no expert, but the oil available from Amazon should be fine *Note that the dealer price, in my case, was actually quite a bit cheaper.
The dealer is also a good source for the filter at this time.
The plug can be removed with a screw driver. (I have the "ECS" plug tool.) and there is a small rubber O-ring on the plug.
Sorry, the oil filter wrench is indeed 76 mm and not 34 as I mentioned above.
Old 09-24-2020, 01:58 PM
  #52
matty1
matty1's Avatar
ok here is a crazy question but will they both fit even if the diameter in the center is different? I tried the small diameter one and I couldn't get it to fit.
The Mahle filter will fit. But it takes a bit of pressure and twisting to get the filter housing to screw in.
Quick Reply: Oil change... Best filters etc
