How do you downshift smoothly?
I have always performed the heel-toe downshift with the ball of my foot on the brake and the heel on the throttle. Obviously this won't work in the Porsche because the pedal is hinged at the floor. So, i was learning to do it oppositly but then heard that because of the fly-by-wire system the throttle is locked when the brake is depressed.
So how do you get a good, smooth, quick downshift during hard driving?
Originally posted by msindi
I just rev-match....
Heel and toeing on the 996 is really hard - I've been trying to learn but no use...
What I do is as I am downshifitng I blip the throttle while I am in between gears (I gues n neutral)....It happens quick but this way once the revs are matched I can get off the clutch and hit the brakes if I need to slow down...I am not the best driver around so....
Originally posted by Oak
No problem here with heel toe downshifting?
IMO the Porsche spacing and pedal height to be relatively easy to H&T. Maybe you feet are too small for the spacing?
-Steve
I can't H&T in the 996, so I double clutch. The key to rev matching when double clutching is to shift back into neutral and lift off the clutch before blipping the throttle - then reclutch to get into a lower gear. This insures that the two shafts on either side of the clutch are rotating at equal speeds before engaging a lower gear. After a few times you'll figure out just how much to blip the throttle for a smooth downshift. It took me some time to get used to it, but after you practice for a while you'll be able to make extremely smooth split-second downshifts.
Basic Sponsor
I agree with Oak. While depressing the brake, I can blip the throttle and raise the RPM's without any problem.
991.2 GT3 RS Weissach Racing Yellow
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
former 1972 911T white, 1984 911 3.2 Targa black, 993 cab white, 993TT arena red, 993TT silver, 996TT speed yellow, 991.1 GT3 white
www.speedtechexhausts.com
info@speedtechexhausts.com
Testimonials SpeedTech Exhaust Videos facebook
2022 Cayenne White
I believe throttle input is suspended/limited with your foot on the brake only when the car is in gear and the clutch is engaged. This situation should not interfere with heel and toeing/rev matching since you'll be blipping the throttle with the clutch disengaged and/or the car out of gear.
-Steve
John,
I concur that you can blip throttle with your foot on the brake and the car in neutral.
All,
Although I have not driven mine in a while (don't ask) I have every recollection of having the ability to blip the throttle with your foot on the brake, clutch depressed and transmission in gear. But, then again, maybe my memory fails me. It certainly would not be the first time. If someone can please verify this I would appreciate it. With Porsche's racing heritage, I would find it ludicrous to think they blocked us out of the ability to heel and toe.
All,
I have no problems heel and toeing in my GT2, or 996 for that matter, (other than mis-timing it the odd time). You can blip the trottle to your heart's content, when the clutch is in. They even teach it at PDE.
But your question brings up a slightly different question, since I too have been told that braking kills the engine management system. Is there any point in learning how to left foot brake a TT for auto cross or track purposes? I would think not.
