996 Turbo Forum 1999-2005
Replaced battery in key fob now it does not remotely unlock the doors
Old 09-09-2014, 05:59 PM
Kevinmacd
Kevinmacd's Avatar
Default Replaced battery in key fob now it does not remotely unlock the doors
So my little red led went out on the key fob, replaced the battery in the key fob, led works and flashes but does not lock or unlock the doors or hood. I can open the doors manually and start the car.
I tried putting the key in the ignition turn on the ignition, not starting the car and then pressing the key fob, still not working. Tried putting the key in the door lock pressing the key fob still not working. Unlocked the door and then pressed the key fob, still no results.
Any ideas? Appreciate the feedback!
Old 09-09-2014, 06:10 PM
"02996ttx50
"02996ttx50's Avatar
when that happened to me it was the guts were bad. had to replace so i did two new fobs same time. sucks but these things are old.
Old 09-09-2014, 06:13 PM
Kevinmacd
Kevinmacd's Avatar
K thanks!
Old 09-09-2014, 06:15 PM
rmc1148
rmc1148's Avatar
I saw a post where the guy cleaned up the inside circuits and it came back to life.
Old 09-09-2014, 08:05 PM
Kevinmacd
Kevinmacd's Avatar
Old 09-09-2014, 10:15 PM
wross996tt
wross996tt's Avatar
try a FOB reset by putting the battery in reverse polarity for 10 seconds, then installing it properly.
Old 09-09-2014, 11:00 PM
"02996ttx50
^ really!? wish i'd known about that one.
Old 09-10-2014, 09:39 AM
Tuxiemama
Tuxiemama's Avatar
Wink
Brilliant but correct
Old 12-10-2015, 07:55 PM
datalis
3rd Gear
datalis's Avatar
Tried reverse polarity and the FOB worked for a little bit then stopped??? Tried with a new battery and got same result...
Old 12-10-2015, 10:28 PM
Kevinmacd
Kevinmacd's Avatar
Yup i did not have any success at all.
Old 12-11-2015, 07:57 AM
"02996ttx50
when all else fails, you need new fob guts, and the hours worth of ( ahem ) "labor" to re-program. may as well just do two fobs at the same time, since the innards eventually gives out on them all.
Old 12-11-2015, 11:12 AM
Carlo_Carrera
Carlo_Carrera's Avatar
Received 2,275 Likes on 1,458 Posts
On one of my keys the solder on one of the battery power connection to the circuit board came loose and was giving me inconsistent functionality. I re-soldered it and now it is fine.
Old 12-11-2015, 11:51 AM
"02996ttx50
congratulations! that makes you ( by my estimate ) a 1 %'er.
Old 12-11-2015, 12:37 PM
Kevinmacd
Kevinmacd's Avatar
Whats so ironic is that quit a few including myself have had this issue by just changing out the battery!
Old 12-11-2015, 02:10 PM
autobonrun
autobonrun's Avatar
Looks like this post is over a year old but here is what I would try before I changed out the FOB internals.
I don't know if changing a FOB battery has the same impact on the software as when it puts itself into a sleep mode after not driving for 4-5 days, but I'd test the same process for restoring it. That is, try locking and unlocking the door using the key. Then immediately, before opening the door, try locking and unlocking with the FOB. At least no alarm that way. If it doesn't work, at least it costs nothing to try.
Quick Reply: Replaced battery in key fob now it does not remotely unlock the doors
