Help! Drivers side lights stay on!
I have DRL lights on my Canadian vehicle and my drivers side rear tail light and side marker stay on during the day....weird.
When car is off all lights turn off. When I turn my headlights switch on at night all lights turn on accordingly.
When I pull the DRL fuse out all DRL lights turn off.
Having DRLs in Canada is a requirement but I look like a fool with one side of my car lights staying on during the day.....
I could really use your help and I don't want to remove the DRL fuse because when I do, my license plate lights don't work at night when turning on the headlights.
Appreciate your input!
I changed the side marker light bulbs and license plate bulbs to LED light bulbs. Do you think that's the culprit?
When you say Left Turn Signal Engaged do you mean my left turn indicator on?
Because my left/right turn signals work when I push down or up on the turn signal lever. I can see each side flashing.
Appreciate the helps guys!
-V
