996 Turbo Forum 1999-2005
Busted F hose, again....
Old 07-21-2020, 05:34 PM
  #31
2fcknfst
2fcknfst's Avatar
Received 4,174 Likes on 3,153 Posts
Originally Posted by Dock
The 710N has been superseded by the 710P.
Alphabetical parts evolution - so logical and easy to follow.
Old 07-21-2020, 05:53 PM
  #32
pancing
pancing's Avatar
Originally Posted by kamlung
Yes those are fine, the part number for 710p is
06A145710P
Old 07-21-2020, 06:59 PM
  #33
Dock
Dock's Avatar
There may in fact be a good reason why they moved on from the 710N.
Old 07-21-2020, 07:07 PM
  #34
2fcknfst
2fcknfst's Avatar
Didn't they split prematurely?
Triangleturbo (07-21-2020)
Old 07-21-2020, 08:31 PM
  #35
Dock
Dock's Avatar
My understanding is that the OEM DVs are Bosch 710A.
I recently had my Baliey DVs replaced, and my mechanic and I decided on the Bosch 710P.
Old 07-21-2020, 08:56 PM
  #36
2fcknfst
2fcknfst's Avatar
I thought the Bailey s were near indestructible?
Old 07-21-2020, 09:09 PM
  #37
Dock
Dock's Avatar
They are.
Old 07-21-2020, 09:21 PM
  #38
2fcknfst
2fcknfst's Avatar
So what went wrong?
Old 07-21-2020, 09:27 PM
  #39
Dock
Dock's Avatar
So what went wrong?
One of them had a very slight operating problem.
They lasted over 17 years without issue.
Old 07-21-2020, 09:39 PM
  #40
kamlung
kamlung's Avatar
did you purchase them online? or locally?
Old 07-21-2020, 09:41 PM
  #41
Dock
Dock's Avatar
My mechanic purchased them and installed them. I believe he purchased them from the local Audi dealer.
Old 07-21-2020, 11:22 PM
  #42
k9turbo
k9turbo's Avatar
when you swapped the original 710's to bailey's. was that considered an upgrade at the time and as part of your tune add on's etc?
i've had the evoms dv's for nearly as long on this car. talk about indestructable.
Old 07-22-2020, 12:14 AM
  #43
Dock
Dock's Avatar
My OEM 710s started "honking" within the first six months after purchasing the car. The car was obviously under warranty, so Porsche was going to replace the DVs; however, I told the service manager that I wasn't about to come back every six months to have them change DVs that were known to be having problems. The information on 6-speed at the time was that lots of owners were experiencing the "honking" issue and we all suspected that this was going to continue until Bosch fixed the problem. At that time (2002) the go-to aftermarket DV was the Bailey (lifetime warranty and no periodic maintenance required.) So I asked the dealer to purchase (on their coin) and install a pair of Baileys (all under warranty), which is what they did.
Most guys back then were using Baileys to get away from the 710s (which qualifies them an "upgrade"), and also as part of a tune add-on.
Old 07-22-2020, 10:44 AM
  #44
2fcknfst
2fcknfst's Avatar
That's not bad for an aftermarket piece, no doubt. You got your monies worth...
Old 07-22-2020, 12:17 PM
  #45
k9turbo
k9turbo's Avatar
yeah, it seems the diaphragms on the original 710's were prone to early failure. i had the same issue with an oem dv on my vw gti also until i swapped it for the more sturdier replacement dv. they get torn and honk like geese flying south for winter.
with the evoms in the 96tt, i've never even inspected them in all these years. seems they ain't broke, and i don't fix 'em lol
Quick Reply: Busted F hose, again....
