I got a failure indicator warning. I cleared it with the stock, it comes and goes . I am having a new sending unit installed Tuesday. Part Number 99660620302. I believe this part sends info to the needle on the gage cluster.
What are your symptoms? Does your oil pressure gauge peg to max?
oil pressure gauge will go to max then suddenly drop to zero. failure indicator goes on. I can clear it with the stalk. it is intermittent. positive this is the issue based upon other owners who have had exactly the same issue.
That's what I figured. I think mine is on it's way out now. Only once in a while it will flake out on me.
Same thing happened to me, sending unit would flake out every once in a while; bought a new one; waited six months and then replaced at same time as other work. Save on labor cost.
I just had it done. Indie 2 hours labor. Total no more than $300. If you go to the stealer bring along some hemorrhoidal ointment to ease the discomfort.
