Clutch advice
#31
Not so sure I believe the engagement higher off the floor scenerio than a C2. I had a C2 and my tt actually to me engages closer to the floor. I did start to have engagement height issues. then I noticed the clutch master cylinder was starting to overflow. Fix replaced the slave and the accumulator and now engagement is where it should be. The accumulator was not holding as it should have been and the slave was replaced due to the overflow and clutch height engagement issues.
#32
