Used OEM Clutch, pressure plate and flywheel
Can I get thoughts on what a used clutch,pp, and flywheel are worth? They came out of car at 6700 miles and assume they have normal wear.
not much, when people take them out it's to upgrade, people rarely put used dual mass flywheel in their car too. And if the car is stock and only needs a stock clutch, than the oem will last a long time, no need to change it unless you are at a very high milleage and your wife can't drive stick very good![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Plus, the cost of the labor is so high that people rather put new stuff in than have to do it again soon after to save a couple of bucks on the parts. Either because it will need replacement sooner or because there is the possibility of a defective component.
Even used aftermarket stronger clutches go for less than half what they were new with almost no milleage. That is not the kind of thing that has a high value on the used market because of the risk. I'd say ask for 50$, i know i'd sell mine for 50$...
It's just too much work to get one in and out to buy a used one and take a risk it's not perfect, just MHO.
