First time that I read a problem with the horn...May be your ignition switch? Weak ignition switch was related in many cases with headlights problems, a/c problems.... But this is only a guess. Can it be the relay? Easy to troubleshoot because you can switch it with the one in position 12, fog light, it is the same part number. The horn relay is in position 10. And the relay part# is 141 951 253 B. The relay carrier #1 is located at your foot , a bit left of the driver side ....
