Ordered a set of Bilstein pss10's...
From Tire-rack lowest I could find. My current set up is stock shocks and H&R lower springs I dont like it my car is to low and its bone shuddering. So after reading allot of posts on this and other forums decided to go with the bilstein's.
I think and hope I made the right choice.
Few questions that I have:
1. Can I start with just the pss10 and after add on some other components or not if not what are they, I dont want to spend a bunch more money at this point.(wife,kids,shoes, dresses...etc)
2. Best set up for street ocasional driving mostly weekends.
3. I dont want the car very low as close as possible to stock height but with improved handling. Here is a pick of the way the car is now.
4. From everything I read Bilstein's pss10 are compatible with my 2005 turbo s but it does not hurt to ask the experts, it is-right?
![](http://i13.photobucket.com/albums/a272/mottts/Porsche/photo%202%20copy%203_zps7c9cddaa.jpg)
![](http://i13.photobucket.com/albums/a272/mottts/Porsche/photo%201%20copy%203_zpsbf743490.jpg)
![](http://i13.photobucket.com/albums/a272/mottts/Porsche/photo1copy.jpg)
I am sure I will come up with some other questions as I get answers.
Thanks to ALL in advance.
Motts.
Motts.
I installed the PSS9 set up, on my 04 when I bought it in 2007. Took some time to get the settings right. Finally got the ride not to hard and the stance right. Street use only and handles like a friggen slot car. Enjoy your set up.
I have pss9 on my tt. I also have camber plates and other stuff. Mine is not as low as yours. I specified mine to be lowered to gt2 ride height. Its low, but not low enough that I scrape on everything. Handles great.
My '04 Turbo is stock, firm riding but comfortable. My DD is a lifted Jeep and rides stiffer but still OK. I did test ride a couple of times an '01 Turbo with PSS9s in the middle of winter and it was bone jarring. Possibly the dampening was set too hard or the cold weather made it ride quite rough. Every bump on the freeway made my kidneys ache. It reminded me of hardtail chopped Harley's I used to ride.
Don't let my experience influence you, just stating I think the car I drove was not set up properly or it firmed up due to cold weather.
I installed the PSS10s in my 03 996TT and they are great! The damping adjustments are really easy and the range makes for a good DD or occasional track car. Go for it!
I recently installed the PSS10s and found they made the car ride smoother than the factory shocks. I keep mine at 2 at all 4 corners and my alignment and height is GT2. Car is much more enjoyable to drive with just the PSS10s. I would recommend one change at a time and I doubt you will need anything else based on what you said in your original post of how you use the car. I would recommend lowering the car and having a rake for better handling. My car was setup by racing guru Chris Cervelli and I never question the master and he never has failed me.
Thanks again.
Sincerely Motts.
PS hate
![typing](https://rennlist.com/forums/graemlins/yltype.gif)
Hey Motts,
I should have been clearer in my message but Cervelli did it all, I will pm you with his contact information. Anyone that knows Chris on RL will vouch for him.
MM
MM
Thank you for your recommendation on the installer Chris! Night and day compare to the previous set up H&R lowering springs vs pss10's.
