Really soft clutch pedal.
Hi guys, as usual I'm after information. I noticed that my clutch was getting stiffer to press on start up after the car was sitting for a few days, it was ok if it had been used that day. Last night I took the car out for a run ( I thought some KFC for supper was a good idea ) and the pedal dropped to the floor without me trying. It went into gear and the pedal did come half way up and I drove off, but was really soft every time I changed gear and only ever came half way back?
I know I need to give up the KFC, but any more suggestions?
Thank you,
Lee.
Thank you,
Lee.
Stiff clutch at start up-accumulator.
Second one sounds like your slave is Bye-bye too. Check for fluid leaking from the container in the trunk-driver's side. You might not have the leak,but that doesn't mean your slave is not going...
It sounds to me you're going to need a slave/accumulator.
I would suggest you replace both the accumulator and slave at the same time. I had the same issue, but started to see fluid seepage at the clutch firewall reservoir. This is common issue with the turbos since they use the power steering pump as an assit for the clutch. The check valves go bad in the slave cylinder, and when the accumulator goes bad it does not allow the pedal to feel normal at start up especially when it has sat.
I've had a look today and fluid was well below minimum. After topping it up, and bleeding the system, the pedal has returned. I can find no evidence of a leak, so where could the fluid have went? I want to bottom out this before I start changing parts.
Cheers guys.
Cheers guys.
Your slave is toast,Pentosin probably migrated to the engine compartment reservoir(power steering).
Yup overflowed at the clutch reservoir and if you look under it you will probably see a lot of wet area. Its on the drivers side front firewall under the black cover. Will probably start running down and dripping on the floor.
