PSS10 Installation question
just got a set of pss10`s for the turbo and I heard that you have to use parts off your old suspension to complete the install. This sounds odd to me and since I have the X73 suspension, what parts do you guys think I need to reuse??? Thanks in advance guys, Mike
OK guys I found out I have to reuse the top mounting perches and the thrust washers, no big deal. I also found out that Bilstein will rebuild the X73 shocks for $75 each. I wish I had known that!!! At this point I am committed to using the pss10 suspension, But if you guys are looking to buy an excellent X73 suspension kit with X73 motor mounts, let me know, Mike
I found that my upper strut mounts were cracked at the rubber connection, a common problem, so ordered new mounts and new bearings. My tech told me NOT to use monoball upper mounts as the noise will appear in about 6 months, Mike
