grumpling/grinding problem when I accelerate out of a turn. What could it be?
Ok, I have an 01' Tiptronic, and I noticed that when I accelerate out of a corner I was hearing a grumbling coming from under my seat area,(possibly a little bit forward of seat). I wanted to eliminate the wheel bearings, so I replaced them, and the problem is still there. I checked for play in the driveshafts, and the Cardan (sp?) shaft, and can't find any.
Any ideas?
Can I unhook the Cardan shaft, and see if the problem is still there? I've heard you cant run RWD on a tiptronic though.
Any ideas?
differential?
I was once getting the same behavior but not when coming out of a corner but when accelerating at low RPMs. It was the transmission controller. The 2001 has older programming which can get confused after driving in a spirited manner for a while. Happened to me after a track day on the way home. Had to replace the programmer with a 2003 unit.
Do a search and you will see more info on the subject. Porsche put out a Technical Bulletin on the subject but did not do a recall.
See if when you accelerate out of a corner in a lower gear at RPMs above 4-5K if you hear the noise. Mine did it from 1500 to 2500 RPMs; after that the sound went away.
Hope this helps.
Tytus
Hope this helps.
Tytus
Tires are sized properly. I tried to see if the rpm was issue by coming out of corners in 1st gear, and it still did it.
-seems like the noise is coming under my seat.
-Now I have also notices a couple of times the last few days of testing for this that I occasionally get a boost of power where the tranny seems to "bang". this almost seems to feel like you are getting the power abruptly. ( not sure if this makes sense.)
