Suspension Upgrade
Thx, Tim
I had PSS9's on my car before I upgraded a second time to Moton Clubsports. The PSS9's still allowed the car to wallow on track. Do your homework before you spend. Your spring selection is what will ultimately make your car handle well or just so-so. You will either have to have the PSS10 springs upgraded and the shocks revalved, or buy a shock that allows you to pick the spring rates. Cheaping out at this point could end up costing you more money in the long run, ask me how I know.
1 Post
Did the KW V3 come with drop links for the front sway bars?
I purchased my used from a Porsche shop owner and need to know, being mine never came with any and was told to use the stock ones. The shop that has my car now said that the stock drop links are rubbing against the control arms.
I had the H&R sways on with my stock set up with out problem and now with the KW I am having issue's.
Bobby Ali
ba
I recently purchased a 996TT and am looking at upgrading suspension and wheels I have it tuned with EVO Stage 2 and would like some feed back on suspension. Considering Bilstein PSS10, H&R RSS Club Sport or H&R Street Set-Up with Eibach Sway Bar Kit for Front and Rear. I have never driven on any setup except for stock. This is a weekend car and I am doing a little DE and plan to do more. After the suspension upgrade I will try to set up some wheels and tires. Thanks for any help.
Steve,
I just went through this process myself and decided to go with PSS10s and a Eibach Sway Bar Kit for Front and Rear. The car is still in the shop getting everything completed. Since I bought my 996T used I decided to spend the money on a full change of fluids (engine, front diff, transmission, brake, coolant) and coil/plugs. I got a bit frustrated with the suspension talk after a while because there were too many opinions and "Internet experts". Of course this is an Internet board. I went and sat down with a few suspension tuners and talked to them. Many are in the business to sell you on things---naturally. Do you need it? That remains to be seen. You will find a lot of folks out there running suspension setups that are complete overkill for the street and who end up making the ride and performance of the car WORSE because they tried to setup a "street car" like a "track car". What is good in one scenario is not necessarily good in another. So you really need to evaluate where the car is going to be spending the bulk of its time. So, if you are not going to be a hard-core track guy then don't go put a Stage III or IV suspension kit on a street car and be surprised that it drives like crap on public roads.
For me, I went with the PSS10 and Eibach sway kit then had a good shop dial things in correctly. Stiff is good (and subjective), but going too stiff with a street car means that it will jump/hop around over bumps, divots, and imperfections in the road. You don't want a car that gets unsettled easily or the driving enjoyment will diminish---I did this with my Corvette ZO6. Too much is bad. Again...I'm talking street cars here....not track/race cars. Two different things.
In summary, start with a good kit of coils (meant for the street) and sways. Go from there.
