Help! At track and need advice
I am at Watkins glen for the next three days and I lost third gear today. I was downshifting to 3rd and suddenly it was like I put the car in neutral. No grinding or noise, just no gear. All other gears work fine. I pulled the center console to see if I could see anything wrong with the linkages, but no luck.
I know I need to find a good mechanic, but tomorrow is Sunday and I really want to know if it's k to drive the car? I drove into the pits and outside of missing 3rd, if is completely normal. I also know that with my power levels I can drive without third fine. What I need to know is if I am going to do more damage by driving at the track over the next three days.
Please help me make this decision.
Most likely you scattered third gear. All the metal from the gear set is floating at the bottom of the gearcase. The risk is getting the metal fragments into adjacent gearsets. Worse if it migrates to your ring and pinion. You are looking at some serious dollars right now. Trashing more gearsets and R&P will require more $$$. I'd flatbed or get someone to trailer the car home.
Id be pretty upset if I found out that someone I was tracking with went out with a blown gear, plus who knows what else may be wrong with it.
Right now your 3rd is cooked. You risk toasting the entire car if you go out again, plus potentially risking those around you. Not worth it just to get a few laps in.
Dont even drive it home. Flatbed it.
