Does this look normal
PPI is a good idea if you are thinking about buying. My 04 has the original hoses and they are still shiny and clean despite the fact that I don't do anything to them.
Those don't look like stock hoses. Again hard to tell. You might see if the seller did something stupid like replacing them with cheap Chinese "upgraded" hoses.
ditto on the dressing then the dust acumulation. Clean them up with WD-40 and then use a good protector on it. The hoses for that 996 turbo, and you might as well replace all of them run about 35.00 each, and I believe there are four of them.
Super Moderator
Needs More Cowbell
Needs More Cowbell
I was taught that as long as the hoses do not compress too readily and are showing not signs of any leakage (much easier to spot of course with radiator/coolant hoses) to leave the hoses alone.
In some extreme cases -- at least with coolant hoses -- one can squeeze the hose with his fingers tips pressed in at the bottom of the hose and near where it connects -- which the area that goes bad first -- and poke a finger through the hose.
I doubt the intake hoses would ever get that bad.
I'm not even sure I'd make any attempt to clean the hoses to make them look 'better'.
In short if it ain't broke don't fix it.
Sincerely,
Macster.
I guess I am old school on replacing the hoses. I'd spend the bucks to replace them, rather than sit by the side of the road and have my wife call me an idiot four not spending 150.00. And perhaps, the aviation side of me steps in as well, if you assume that one hose is bad, and assume that all four were built around the same time, same factory, and subjected to the same cooling heating cycles, and have the same MTBW..it just makes sense.
It has not been established that the hoses are non-functional, or are deteriorating in any way. Replacing them because they are dirty or have some discolored surface protectant on them would be like having your car repainted because it was dirty.
