996 Turbo Forum 1999-2005
Adjustable front lower control arms?
Old Apr 27, 2012 | 09:40 PM
Carlo_Carrera's Avatar
Carlo_Carrera
Default Adjustable front lower control arms?
Prices ranges? Anybody know who makes the best ones for 996TT? The best bang for the buck? Just looking to get the front camber to around -1.5 to -2 degrees.
Old Apr 28, 2012 | 01:00 AM
Basic's Avatar
Basic
Rss or factory gt3, prices are easy to find.
Old Apr 28, 2012 | 04:12 PM
Carlo_Carrera
Who is Rss?
Old Apr 29, 2012 | 07:35 PM
Macster's Avatar
Macster
Came across some Porsche techs installing some made by Tarrett. The techs had good things to say about the arms.
When (if) my Turbo ever needs any suspension hardware I think I'll go with these to pick up some extra alignment adjustabilty.
And in fact the Boxster may need some new suspension hardware at its next tire replacment (sometime in May as soon as the backordered Michelin tires come in) and I may go with Tarrett for the Boxster.
We'll see what the cost diff between factory and Tarrett is.
Sincerely,
Macster.
Old Apr 29, 2012 | 09:59 PM
Basic's Avatar
Basic
Dont think tarrett makes lower control arms, they sell factory gt3 ones. You might be thinking about rear upper dog bones.
Rss is road sport supply, google them. Their lower control arms are beautiful.
Old Apr 29, 2012 | 10:22 PM
DEjunkie's Avatar
DEjunkie
Would it make sense to replace the LCAs without replacing the full suspension? (sorry for the borderline thread jack)
Old Apr 30, 2012 | 06:25 PM
ECS Tuning's Avatar
ECS Tuning
Former Vendor
We carry both OEM 996 and 997 GT3 control arms.
Old May 1, 2012 | 03:55 AM
powdrhound's Avatar
powdrhound
I bought a set of the GT3 lower control arms last year for around $800 from the dealer for the set. It was a hell of a deal. The arms come with 7mm worth of shims for each side (3x 2mm and 1x 1mm I believe) which will give you roughly an extra 0.8 degrees of camber per side. You will effectively widen the track by 14mm. If you have Xenons, make sure you get the required bracket for the Xenon leveling arm as I believe that is an option. The trick with the GT3 arms is to mount them backwards from what Porsche shows in their manual (in other words put the left arm on the right side of the car and vice versa). The arms are identical except the position of the off center mounting holes. You need to have the LCA offcenter mounting hole (the one the lower diagonal arm will attach to) pointing toward the front of the car. This will assure that with 7mm of shims your caster will remain unchanged and you don't have any clearance issues. It worked perfectly on my car. If you add more than 7mm of shims you will increase caster (pulls the front wheel forward) and less than 7mm of shims will effectively reduce caster (push the front wheel back) from the static fixed LCA caster setting.
Old May 5, 2012 | 02:29 PM
Carlo_Carrera
Great info, thanks.
Old May 7, 2012 | 12:59 PM
Macster's Avatar
Macster
You're right and I'm wrong. I got Tarrett mixed up with RSS. I came across some pictured in a car mag (Excellence) and realized my mistake.
And you are right about being beautiful too. With that hardware installed too bad one can run the in open wheel mode -- sans the front fenders at least -- to show the hardware off.
Sincerely,
Macster.
Old Sep 13, 2013 | 11:11 AM
manny_g's Avatar
manny_g
When I lowered my car, my front camber settings were forced out of factory specs. I want to keep my lowered ride height, but want the front camber settings to match factory specs as much as possible. Right now i am about -1.2 Can I adjust the camber with the stock suspension parts or do i need adjustable arms. If a need adjustable arms are they the lower or top that i need and where would be best place to get them.
For the rear suspension, I replaced the rear upper control arms with RSS to meet factory camber settings.
thanks in advance for the info...Manny.
Old Sep 13, 2013 | 02:50 PM
powdrhound's Avatar
powdrhound
The split lower LCAs will allow you to dial in more camber over the stock units, NOT less. At -1.2 you are perfectly fine and super duper conservative anyway. No need to monkey with it. There are no upper arms in the front by the way.
