2001 or 2002 996 TT
7th Gear
It looks like my pocketbook and what I got out of selling my Cayman S will put me into either a 2001 or 2002 996TT.
Any advise on one year being more problematic than the other or are the usual suspect problems the same for both years?
Thanks again for all who have helped me in my search.
Bill
Bill
No difference in the standard minor problems, The 2002 did have its structure rigidity increased by 25% to provide better handling. The 2002 also got a glove box and dash retractable cup holder along with a few more available options.
Super Moderator
Needs More Cowbell
Needs More Cowbell
There was a TSB for the 2001 996 Turbos regarding a check valve on a turbocharger oil line.
IIRC, the updated part has a blue dot.
Early 2001's also came with front bumperettes (aka "warts") and/or solid spoke wheels.
The former was due to a stupid US DOT requirement (which was thankfully changed/reinterpreted) and the latter was simply due to vendor supply.
I prefer the 2001 since a glovebox adds unnecessary weight
I'd buy the nicer example of the two.
Back a few yeares looking into it certain individual parts that make up the chassis are different PN's , the whole chassis number is the same. I was told if you replace the chassis you get the updated version.
Also, Excellence magazine last month has an article on the 996tt and also states the 25% structual increase in rigidity. Since i did found the individual parts of certain chassis parts betweeen the model years I feel it supports the rigidity claim. It would not surprise me that due to inventory that all the parts since body style is interchangeable will be reduced to one part number between the two, which would indicate that the 2002 and up parts can be used for the 01. So i guess if you mess up the chassis the on the 01 you would get the higher level parts for replacment.
Bill
Bill
The only problems mine had were remedied by the previous owner. Most of the problems were due to the car sitting for long periods. It needed a new clutch/slave accumulator, and new tires but thats about it. Whatever you find, get a good PPI to make sure you know what else you are dealing with. The engine is bulletproof when maintained properly, so good records are a must. You wont find hardly any problems with the drivetrain. Most problems tend to come from the electronics like nav and window regulators.
Good luck, you will love the tt
paul
Cars that get regular use - can get regular attention, regular maintenance, and regular repairs made.
The few examples of cars that I have seen on here with "high" mileage seem to run quite well without strange issues.
Actually there is a structural change between the two model years. Porsche had to weld tubing for bracing behind the "B" pillar and the seat belt retractor mount. It has to do with a side impact area. I have verified it myself. If you welded in the 4" piece of tubing, and the metal strap, you would have a 2002 chassis..
