996 Turbo Forum 1999-2005
Experiments with the PSM
Old Apr 22, 2012 | 11:44 PM
Carlo_Carrera's Avatar
Carlo_Carrera
Originally Posted by Twinturbofan
To SSST,
The best way to "get seat time" in your car and learn how it behaves at the limit is to take it to an autocross. After a few runs, kill the PSM and ABS and you will educate yourself very quickly on how to handle your car.
How do you kill the ABS? Pull the fuse?
Old Apr 30, 2012 | 04:47 AM
SimonK's Avatar
SimonK
I don't like the handling of the car with PSM off. First you get understeer, if you go ahead this turns into controlled oversteer which is fun if within limits, however if you really over cook it - a nasty slap of the back happens as rear weight builds kinetic energy. Unless you are really quick (Wyatt Earp quick) via opposite lock you then crash! Don't do it if grip is poor because; now you have it - now you don't, is the order of the day unless on the track with ample run-off areas!
