18x10 and 18x12 wheels
andresito, could you describe the wheels a little better? Are the TR Motorsport wheels 18 X12? do you know the offset? what condition are they in?
Which are the 18 X 10 wheels? the ones with tires in also in the photo? Are those from a Cayman or a 996/997?
sorry doing it from my phone
18x10 front et40
18x12 rear et45
excellent condition, they are polished. i was going to use them for track and drag racing but i need to fix too much in the car and i am tired of putting money into it
18x10 front et40
18x12 rear et45
Do you have the front ones too or 800$ is for those 2 in the rear and the other 2 different ones for the front?
You have to make it clear man otherwise you can't sell them.
brand is tr motorosports as stated in your quote and they are forged.. they used to be made for tirerack.
the pic only shows 2 because the other 2 are in a box, price is for all 4 (2 fronts and 2 rears)
weight is 21lbs front and 23lbs rear I believe
the wheels with tires in the background were a set of 997 turbo wheels that I sold recently
$800 for the 4 TR forged wheels is a very good price, depending on the condition of the wheels. You may want to protect the face on the one wheel you have laying sideways with the other rim edge resting on it. better pics of ALL 4 wheels and a good description should get these sold rather quick.
I have a set that I'd like to get around to tinting or refinishing in a gunmetal color. Just havent' been eager on spending mod money.
GLWTS
GLWTS
10" fronts would worry me. You would need at least 255s and getting the f/r diameters within spec might be tough. I also think they would rub at full lock. You would probably have to modify the liners and possibly roll the fenders.
you can use them easily for daily driving if you have coilovers, for track then they would fit a RWD car better due to tire specs etc but they will fit.
I test fitted them with R888s and drove around a bit with them without a problem. I did not take pics because I was not thinking of selling them and the tires belonged to a friend (he has a shop with tire mounter) so he let me mount the tires for a little bit then I took them back off.
