car pulls right when I left off gas, why?
My 996GT2 is pulling to the right when I left off the gas. The alignment is perfect. Tires are in great shape. Could the problem be motor mounts?
As has been already suggested motor mounts are of course suspect but be sure you investigate other possible causes too.
Sincerely,
Macster.
Super Moderator
Needs More Cowbell
Needs More Cowbell
Has the car been corner balanced?
Brake pads dragging?
Rear differential issue?
Is it the same coasting in neutral and using engine braking?
If you repeat the test in Australia, does it pull to the other side?
One thing you can do is have someone follow your car. Have they pay close attention to your exhaust tips. Do a few accelerations and de-accelerations. Do they notice if the exhaust tips dive up & down? If so, this would further support your notion about worn motor mounts.
Lewis' comment about the differential is also a possibility.
yes, recently
no
no
there's no engine braking when in neutral
yes, recently
no
no
I would guess that something is not correct with the alignment. It could be a ecentric that is slipping from not being tightened. I would also verify your corner balancing. Did they put weight on your seat and floorboard? 180lbs? 200 lbs?
Super Moderator
Needs More Cowbell
Needs More Cowbell
sorry I wasn't clear.
I meant is the 'pulling' the same when coasting (neutral) and when decelerating under engine braking?
In other words, drivetrain loaded vs non loaded.
Jim
The car was scaled and aligned at a professional raceshop while I was present. The tracking and handling of the car is perfect other than the 'off-throttle' pull to right. Car was scaled with driver weight in seat and floorboard.
Is it a constant pull to the right or a short, sharp pull immediately after lifting off full throttle? Do the left and right tires have equal wear? I will get a lateral "snap" in my GT3 when lifting off quickly from full throttle if my rear tires have differing wear levels side-to-side (i.e. if I have been running on a primarily clockwise track and didn't rotate my tires side-to-side halfway through the weekend).
In this case I think your next step would be to revisit the shop that did the alignment and rely upon the expertise there to get some ideas.
One idea will probably mean getting the car into the air -- with the tires/wheels supporting the weight of the car -- and carefully checking for any looseness of any bushing/links and carefully checking for any signs of distress -- crumbly bushing rubber, rubber dust, signs of excessive movement at a bushing, and about a zillion other things. This involves among other things giving every link, rod, whatever a grasp and a good shake to try to locate any excessive or abnormal play or looseness.
If the above turns up nothing then again raising the car this time with the car's weight supported by the body's lift points and doing the same checks as above.
It is hard to imagine a cause of the car's pulling when simply lifting off the gas at something less than ballistic speeds not being rather obvious when the car is subjected to qualified and certainly an experienced professional's inspection.
Sincerely,
Macster.
