fluid leak?
fluid leak?
2003 x50, manual, 15k miles. sitting about a month in the garage. leaking red fluid from both rear corners between exhaust heatshield and body panels. can anyone tell me whats leaking?
fluid is oily so i don't think its coolant. looks like atf to me but i didn't think there was any atf in a manual.
coming from above the heat shields so i can't trace it.
Should be Pentosin in the wing arms, unless the fluid was changed. Pentosin is green. Anitfreeze should be pink, and does feel oily. The smell of antifreeze is pretty distinctive too. Smell the drip, then open the coolant reservoir and compare the odor.
