Reduction of the engine rattle that many 996 turbos exibit.
#46
![order](https://rennlist.com/forums/graemlins/order.gif)
I'm sure there are those that intend to keep the car until 200,00, but how many of us plan to do that? Maybe if you drove 200 miles a day I could see racking up that mileage, but it would likely be all easy hi way miles which would attribute to higher mileage potential. ..
0w-40 is a blanket oil that is better in cold climates than it is in hot. I've been working on engines my entire life, and I don't know one engine builder that would recommend it. Of course I don't know any engine builders in Finland
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
Besides, 5w-40 and 5w-50 are approved by Porsche. Why do you think they would approve an oil that was not safe to use? Don't let the diesel aspect of the oil that we are discussing throw you off. Rotella T6 and Delvac ESP are very high quality oils with additives that keep it more stable and have many other benefits in our engines as well . And it is a true 5w-40.
If however you are satisfied with what you are using, then you should continue to do what makes you comfortable, and I am not suggesting otherwise.
#47
Super Moderator
Needs More Cowbell
Needs More Cowbell
So let me try to understand what you said.....
You don't like (Mobil 1) 0W-40 because it is like water when it's hot.
So, you chose to run (multiple vendors) 5W-40 instead.
I guess the 5W-40 is a different 40W than the 0W-40?
Opinions on oil viscosity are like a&$holes ... Everyone has one and they all stink.
But they are amazingly similar, across every forum.
Coming up after the commercial, the differences in formulations over time for the same brand's viscosity.....
#49
Let's face it. That rattle is normal for this car. I don't like to hear it get too loud, but it is part of the "Charm" and the oil can make a difference in the noise. Yet this is one of the most reliable and durable super cars on the road.
All I know is that when I mash the go pedal, I really like what happens next. When I accelerate through a sweeper or goose the pedal in a tight turn, the handling is sublime.
Quitchyer bitchin' and drive the damn car.
Its unacceptable. You can choose to ignore it and "drive the damn car", but when something fails and porsche tells you to go scratch and you get the $20k repair bill, perhaps you may be singing a different tune.
For instance, German castrol Syntec 0w-30 is basically a 40wt, while Mobil 5w-30 is much closer to a 20wt.
I don't understand why people are so scared of running a different oil. I've yet to see an engine experience catastrophic problems because someone ran one synthetic oil (diesel or otherwise) of a similar weight instead of the recommended oil. I think just about everybody agrees that M1 is not the best oil out there.
#50
Not all 40 weight is the same. There are many different base stocks and additives than can substantially change the oils properties at operating temperature.
Btw, I am a very well versed on the effects of oil on engines, being in the business for over 20 years, so I would hope my opinion isn't worthless or like someone's *******.
Again, if you like what you are using, keep using it!
#51
Super Moderator
Needs More Cowbell
Needs More Cowbell
#55
All due respect to your mechanic. However, that is not true ! ![order](https://rennlist.com/forums/graemlins/order.gif)
0w-40 is a blanket oil that is better in cold climates than it is in hot. I've been working on engines my entire life, and I don't know one engine builder that would recommend it. Of course I don't know any engine builders in Finland![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
#56
Arguing about which oil is the right oil is like arguing about which bottled water is best. Use what makes you feel all warm and fuzzy. If your engine is going to fail due to oil, chances are it will be an oil flow caused issue not a viscosity or weight issue. If you want to know which oil is right contact a reputable builder and do blackstones. If you are superstitious you should check rune stones or ask a psychic which oil to use. Their has never been a conclusive discussion here on oil ever. If rotella works for you and you hear less noise, run it. If you are on the fence run it and DO A BLACKSTONE ANALYSIS!!!
If anyone here wants something to worry about, how about the lifter failures that have actually happened? Or the debt ceiling? Darfur? Or the economy?
#59
Listen, I am with you. I have been down this road. I was not able to find one confirmed engine failure caused by IMS rattle. The engine you linked in the video was torn down, rebuilt and the IMS replaced. It caused the noise to go away for a while. At least until the engine broke in. I believe that the noise your engine makes with different oils is a sign of one particular characteristic of the said oil. The only to really tell what all the characteristics are is with oil burn tests over a period. if you want to be cautious and and proactive, change your oil every 3000 miles with 5w40 synthetic with a good additive package and check your filter every oil change for metal. I am not disagreeing with your thoughts or concerns, I am just saying it has been beat to death with zero results. If you get good results with what you are doing in the long term, prove it with data. But the whole "I feel good about this oil" thing will only lead into an argument with no actual data. And a whole bunch of people stressing more than enjoying their cara. Trust me.
#60
Super Moderator
Needs More Cowbell
Needs More Cowbell
Hmmn, data.
No, that would never work here.
Blackstone Oil Analysis...
How many? How often?
What does the data correspond and correlate to in the mechanical world of the engine?
At what point, time, level do you tear apart your engine to avoid the catastrophic event which the oil analysis is predicting?
Looks like we're going to need more Preparation H.
Every forum seems to have these no win threads.
The Mayan calendar can probably predict the life of a 996 Turbo engine with 0W-40 better than the human ear or Blavkstone labs.
![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
