996 Turbo Forum 1999-2005
Reverse light relay location?
Old 07-27-2011, 06:35 PM
Carlo_Carrera
Carlo_Carrera's Avatar
Received 2,524 Likes on 1,594 Posts
Default Reverse light relay location?
Anyone know where this thing is?
Old 07-27-2011, 09:10 PM
jpflip
jpflip's Avatar
According to the wiring diagram it is on the relay support #2 located under the rear seat besides the ECU....This is for tiptronic I guess???
Old 07-27-2011, 09:17 PM
Carlo_Carrera
Yes, the location with a Tip trans.
Thank you for providing such a clear and detailed answer.
Old 07-29-2011, 05:21 PM
jrockwood
jrockwood's Avatar
Curious what is going on that you need this ? I have no reverse lights now and cant track down issue.
Old 07-31-2011, 05:49 PM
Carlo_Carrera
Same problem here, no reverse lights sometimes. Do you have Tip trans?
If yes, there are two possible issues. One is this relay which is cheap and easy to try. The other is the reverse light contacts in the shifter which is a total pain to get to, disassemble, clean the contacts and reinstall.
I am trying the relay first. ;-)
Old 07-31-2011, 10:54 PM
jrockwood
jrockwood's Avatar
carlo-- yes mine is a tip...let me know what you find. Mine has parktroninc which is also not working.
Old 08-01-2011, 10:19 AM
Carlo_Carrera
I will, what is parktronic?
Old 08-01-2011, 10:37 AM
jrockwood
jrockwood's Avatar
Parktronic is Porsche's back up system.
Old 08-01-2011, 06:09 PM
Carlo_Carrera
SUCCESS!!! My back up lights are now working.
You don't even need to buy a relay because there really isn't one there, it is just a junction point with a very small four pin bridge type jumper connecting the wire leads, see the photos below.
I slipped the two light gray wire lead holders from relay position #6 by pinching the two small black tabs on the side together.
Then just pry the one light gray holder you need to get to out of the clip that holds the two together.
Then you can see the small four pin jumper that connects the wire leads together. My car only had two wire leads there even though there is space for four. Your car probably has more for the Parktronic system.
Pry the little connecting bridge out with a small screw driver and clean it well. Mine had just the slightest tarnish on it but that was enough to stop the current.
I tested the current through the wires with a test light by having my wife start the car and putting it in reverse. I got a good positive flow on one and good ground with other. Just to check I put a piece of speaker wire connecting the two and the reverse lights came on. I then installed the cleaned bridge and the lights came on.
Problem solved!
Old 08-01-2011, 06:13 PM
Carlo_Carrera
And a super big thanks to jpflip for knowing where this stuff is.
The wiring on these cars is unbelievably complex.
Old 08-01-2011, 06:51 PM
jpflip
jpflip's Avatar
Good Job Carlo!!!! Congratulation!
Old 08-02-2011, 02:35 AM
jrockwood
jrockwood's Avatar
Just tried the same process with no luck. Attempted jumper with wire and cleaning contacts. Where should I go next?
Old 08-02-2011, 02:37 AM
jrockwood
jrockwood's Avatar
Btw which one of two assemblies did you test...the one with 2 wire leads or 4?
Old 08-02-2011, 09:42 AM
Carlo_Carrera
I tested the one with 2 wire leads. The one that was in position #6, sub position 20/1 of the wire diagram. The one at the top left.
Did you start the car and put it in reverse and check the current at the wire leads with a test light?. When I know that result I can then help you further.
If I were you I would check both bridge connections at that location.
Old 08-02-2011, 12:52 PM
jrockwood
jrockwood's Avatar
I get 12 v from my volt meter on the bottom of the 2 leads when reverse is engaged.
Quick Reply: Reverse light relay location?
