Check oil level with car running or not?
Seriously, it's mostly from reading threads like this on oil pressure. Most run a little above or below 2 bars. That seems to be the norm.
Mine's a bit higher although it settee at about 2.25 after some extended running in 100+ ambient temps yesterday.
The tech at my dealer said it is on the high side of normal, but absent any other symptoms like knocking, overheating, bouncing pressure guage, etc, it isn't anything to worry about.
Probably at 2.25 bars because you had the AC on with those temps, idles a little higher than when off.
Mine is a little above 2 bars too when the AC is on.
