ECU flash should i?
ECU flash should i?
Hi Guys,
i just got my 996TT (Blk/Grey, Tiptronic, stock setting) couple wks ago. I go thru this forum for the ECU flash and so much positive feedbacks, are there any bads after flashing? I plan to keep my stock air-flow, exhaust at this moment. should i upgrade my ECU
thx so much!!!
thx so much!!!
A good flash will allow the turbochargers to start to spool up quicker and with MORE flow. The result is more torque. Engine torque will allow your tippy torque converter to transfer the power to the wheels sooner.
You won't have to worry about your "clutch" yes the tippy does have a clutch pack but at the ECU flash level, you won't harm it.
If you haven't replaced the gearbox fluid I would strongly recommend the oil change.
Thks alot, i will ensure the gearbox fluid changed before doing it!
But, honestly, how much Horsepower do you really need? With the flash on my Turbo, I am adding an additional 90 horsies to the 420 stock. With 510 HP, this car just FLIES. I don't know what I'd do with another 100 HP on top of THAT!!!
larry
