Watch the brake rotor holes... Time..
to wash the brakes, at least for my Turbo.
As the pic below shows, some holes are starting to accumulate some brake dust. When I first bought the car almost all the holes were completely filled with brake dust, rust. I used a DIY car wash wand to blast -- though I was careful to not get the wand tip too close to the pistons and their dust covers -- the dust out of the holes.
![](http://i55.tinypic.com/mizc07.jpg)
Sincerely,
Macster.
Sincerely,
Macster.
So glad I don't have to deal with that junk anymore...
![](https://i145.photobucket.com/albums/r226/Mikelly_2006/Mike%20911%20Twin%20Turbo/7d3956bf.jpg)
Had these since 2008!!
Mike
Mike
way to rub it in mike
Perhaps junk refers to any rotor with cross drilled holes and their propensity to develop cracks when subjected to heavy use.
(Although real boy racers swear by the drilled AND slotted design.....)
Junk, as in refering to the cross drilled holes. Pad deposits build up in those holes and cause all kinds of problems for those who track their 996s, especially if they're using pagid orange compound pads. Of course, if you don't track your 996TT (Or drive it much, for that matter) then it's no problem. How many miles on your garage queen again?
Dock, Any cross drilled rotor is "junk" on a street car, in my opinion, which last I checked, is all I care about.
Mike
Mike
I switched to the Girodisk slotted rotors 1.5 years ago. My car goes to the track, so the cross-drilled rotors developed radial cracks that made them unusable after two weekends. My front Girodisks went about 15-18 track days, including 6 full ones at Road America and never cracked. They eventually wore down to the slots. I find it worth the difference in price.
When I had the cross-drilled rotors, I used to clean the holes between track sessions with a locating pin. Slow. Or with compressed air. Fast but you do put a lot of dust in the air that you eventually breathe in.
Jon
Jon
Except for the fact that slotted rotors are not as prone to crack, it is good to have wear indicators combined with normal grooves - gives a very clear indication of when it is time to change them. Much better clues than to find out at the end of the main straight by being informed by a soft pedal indicating that they are not able to cope with the heat radiation.
Hey dock, Why is everything with you a debate? Hmmm... weren't you the one that gave Dell a bunch of crap over a garage door opener mod because this was a Porsche, ment for the track or some such nonsense?
The cross drilled rotors on a street car serve no purpose beneficial to braking performance, especially with the current pad materials being used in over the road cars. Ask any rep of any of the common brake pad suppliers...
Furthermore, the pad wear sensors will function with any rotor surface. The reality is that Porsche chose to use cross drilled rotors more for style and less for function on US Spec cars. Again, this is my opinion. It's also why I swapped my fronts out to something without drilled holes that heat check and crack.
And Dock, Porsche may or may not have built this car to be tracked. Many of us DO track them, with great success... But the reality is that the same design rotor is on their track oriented GT3. It would only stand to reason that the design is either sufficient on both models, or insufficient on both models. Based on the number of GT3 owners who swap their rotors out to something WITHOUT cross drilling, that tells me all I need to know... They're JUNK, in my opinion.
Mike
Mike
Hey Mike, why do you consider questions and discussions "debate"??
For street driving, Porsche claims the cross drilled rotors produce both lower temperatures, and better performance when water is present. And even if they were not being completely truthful about this (and I have no reason to believe they are being dishonest), the fact that their cross drilled rotors may not provide any additional benefit other than looks does not IMO mean they are "junk".
And 57K (+) miles on the original pads/rotors.
But both the pads and rotors getting thin. Should probably start ordering parts for a brake job one of these days.
Sincerely,
Macster.
Sincerely,
Macster.
