Exhaust heat shields - necessary?
I'm in the midst of putting my 2002 996TT back together after major work. I see my exhaust (not turbo) heat shields are rotten. Dealer wants $600 for parts to fix. My question is - do I need them?
Other cars I've had with rattling heat shields I've just taken them off and carried on - NSX and a boxster. Any good reason for keeping them on a 996?
Cheers for any answers,
Matt
Matt
So you re saying the car is non turbo, if that is the case thecats are right up against the rear bumper, if it is a turbo, the muffler gets pretty hot, and the bumper is plastic, still an exposure.
Sorry, you misunderstand me. The car is a turbo, and there are two different types of heatshields - one for the exhaust and one for the turbo. What I meant was can I leave the exhaust heatshields off and that I'm re installing the turbocharger heatshields.
Matt
Matt
With the heat shields removed the heat from the exhaust will cause the plastic bumper to over time deform. The additional heat that makes its way into the engine compartment, rear body area, wiring, lights, etc., can't be good for those components either.
Price a new rear bumper cover, prepped, painted (and include the necessary adjacent panel paint blending too), and installed to make that $600 heat shield replacement bill seem tiny in comparison.
Sincerely,
Macster.
As Macster has mentioned the heat will destroy your rear bumper AND you rear tail lights.
The turbochargers can see over 1400 F , the turbo heat shields are NOT enough to keep the heat from rising and cooking the plastic.
I don't think so. A good sheet metal/fab shop is going to charge big bucks to fab something up. And even then the shop will be hard pressed to fab something up as nice as the factory shields.
The factory shields are nicely formed, with stiffening ribs, and other surface features to keep their buzzing down, have IIRC some insulating properties to resist transferring the heat, and have very complex contours/shapes to fit alongside/against the body panels to protect them yet not catch air.
For $600 the OEM shields are cheap and do the job.
Sincerely,
Macster.
Sincerely,
Macster.
OK, if some heat dissipation is needed, would an exhaust wrap do the job? Still very wary of paying $600+ for something that shouldn't cost a fifth of that!
CCC, how are you going to hand wrap the CAT's and the transition to the muffler?
I think that you need to buy yourself a Honda. Drive it for 200K. Just add oil.
The heat shields are hydroformed with multple layers to absorb the heat. Find a picture of the Carrera GT heat shields around the headers.
You are driving a car in a climate that requires expensive parts to be replaced. It is very common that the wastegate arms and linkages on your turbochargers corrode. That's going to be a $2000 repair.
Again the cost of ownership on a 8 to 10 year old car requires a cash reserve for maintenance.
$600 for a properly formed/fitted heat shield is not bad imho.
![](http://i52.tinypic.com/nwxx5t.jpg)
Sincerely,
Macster.
Burgled
I didnt know they were that extensive.I was thinking along the lines of the ones on my 964 that are just curved metal and cost about the same.
jimq...that is the coolest little puppybird EVER ...cheers!
I don't know how you intend on using your Turbo, but to give you some idea of how hot the entire exhaust can actually get, I had a friend video tape my car just after sunset one evening at a track event here in the states. He was amazed that each of my exhaust tips at the end of a long straight would be glowing a bright, bright orange. I can only imagine how hot the pipes coming out of the cats must get.
Gotta figure Porsche put them there for a good reason, right?
If it were me I would be sourcing "new" new shields.
Good Luck!
H_D
