Does 997SSK stress tranny internals at all?
#32
Dock,
The easiest way to not be "ham fisted" is to not put a shifter in a car that is more difficult to use. Shorter shifters require more force from the driver period. If you want another perspective on short shifters, talk to somebody who rebuilds transmissions like G-box.
#33
Normally it doesn't increase the load on the shift forks. But a short shifter has a smaller shift pattern, does it not? That makes a misshift easier to happen verse a stock shifter, wouldn't you agree? Kinda like trying to throw an apple at a barrel verses a quarter. And what do most people do when they miss a shift? They panic and struggle for a gear. This also causes the natural reaction of applying more force quicker. Under normal shifts this isn't an issue. A smooth normal throw shifter is often times quicker because it is more precise and smooth. You also have less chances of miss shifts.
#34
It's a B&M and not a Porsche manufactured part. My experience with the B&M shifter in multiple makes/models hasn't been good... Corvettes, Mustangs, now porsches... No thanks.
#35
The leverage point change does not cause the shifts to be less smooth or be more notchy.
Additionally, the leverage point being different does not effect the accuracy required to accomplish the direct fore/aft shifts (1-2, 3-4, 5-6). And I'm not so sure it even effects the the left/right distance the shifter travels in neutral.
My personal technique is to allow the shifter spring (in the neutral left/right track) to position the shifter properly; directly below 3rd/above 4th for the 2-3 and 5-4 shifts.
There is never a good reason/excuse to bang/force gear changes, regardless of the shifter. Bent shift forks are a driver issue, not a SSK issue.
#36
Kevin, My take on that is that the transmission was jacked up by the previous owner. I knew there was a notchy issue with the trans when I bought the car, and should have insisted the issue be resolved before I bought the car. I didn't. The B&M may have been the issue, or it may have been the previous owner's inability to adjust the cables.
In doing research on the various shifters out there, I ended up replacing the B&M with the 997OEM, and then the 997SSK.
From my friends at Suncoast Porsche:
When the 2010 GT3 Shift console first arrived, we put them all in a row and examined them all. We didn't notice any throw-difference between the stock and GT3 version. They both would extend to the same positions, the 997 short shifter was the only exception.
The 997 GT3 (2010) is not a short shifter from what I've seen, you will notice that that the GT3 and standard version are at a parallel position.
Pics can be seen here on page 4 of the thread...
Mike
Mike
I'll go out on a ledge and say, with Mike's luck with tranny rebuilds I would strongly recommend the 997GT3 for his application. Truthfully for his wallet, I wish that he would make the switch (my opinion) With the exception> if he is running the heat treated billet shift forks. They will handle the track duty cycle.
I have welded 997 CUP car sequential shifters that get ripped right off the hinge. It is amazing to see the force that is placed on any shifter.
#37
My original entry into this thread was based on Larry stating that Kevin had been seeing problems with the 997 SSK. I wanted to know what kind of problems the 997SSK was having. The discussion that has followed indicates to me that it's not a case of the 997SSK having problems, it's a case of some drivers having problems with their technique.
I've had a B&M shifter in my Turbo for over seven years. No problems at all with the shifting.
#38
B&M made the OEM 996 Turbo shifter.
OEM 996 Turbo shifter = manufactured by B&M
B&M Short Shifter for the 996 Turbo = Manufactured by B&M
(Back in '04 I called B&M, worked through several people to get to one of their design engineers, and asked him about this directly).
#39
Examples of the three shifters, 997, 997GT3, 997SSK...
![](https://i145.photobucket.com/albums/r226/Mikelly_2006/997SSK%20DIY/ShifterPic3.jpg)
![](https://i145.photobucket.com/albums/r226/Mikelly_2006/997SSK%20DIY/997Shifterscomparo.jpg)
![](https://i145.photobucket.com/albums/r226/Mikelly_2006/997SSK%20DIY/997Shiftercomparo2.jpg)
Since spending LOTS and rebuilding my transmission with new mainshaft, syncros, gears, and all internal parts, my shifter works very well. It is not notchy, and the transmission shifts accurately and precisely. I have zero issues with the function of the 997SSK, which has only been in the car since the new trans rebuild was completed.
Mike
Mike
#40
I don't buy that for a second. Not that you made the call and spoke to someone there who claimed that. But I don't buy that Porsche would contract to a company like B&M to make their "OEM 996SSK Part". I just don't see that in 1 million years...
It wouldn't be the first time a company lied to a customer...
And Dock, how many miles you have on your car in 8 years? You have to use it in order to have it develop problems there, man!
Hahaha
Mike
Hahaha
Mike
#41
As I said, if a driver allows the spring to position the shifter horizontally (in those cases where the spring is designed to do that), there is little to no chance of a misshift (even if the horizontal distances are reduced from those on the OEM shifter).
Additionally, even if a SSK requires a little more driver attention (until he engrains the technique), that does not mean there is a problem with the SSK itself.
#43
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
I agree the short shifter has shorter fore/aft throws. I do not agree that shorter fore/aft throws make misshifts easier.
to help you understand. It all comes to taking a possible issue with ones shifting(which may be caused by tranny issues, technique or other shifter issues) and trying to fix it with a short shifter. If you have tranny issues or are having issues shifting due to technique than a short shifter will only be a bandaide that can compound the issue. If you shift perfect 100% of the time, than it won't be a factor for you.
As far as other tranny damage goes, if you increase the speed you shift and do not double clutch you will add more wear to the synchros. If you don't believe me, talk to a tranny builder. Trained race car drivers transmissions see alot of synchro wear and they know how to shift too.
#44
I believe the problem some drivers have is one "shortcutting" their shifts when they pass through neutral, attempting to make what is essentially a "straight line" shift gear-to-gear instead of going horizontally through neutral. If the driver would either manually guide their shifter horizontally in neutral until it is in the correct left/right position, or allow the shifter spring to position the shifter under/over the chosen gear, they wouldn't have an issue with the SSK shortened horizontal distance. In terms of the 4-5 shift, if the driver moves the shifter horizontally to the right in neutral until he reaches the stop, then moves the shifter forward into 5th, there should be no issue with the shorter horizontal distance. Similarly, on a 3-2 downshift, if the driver moves the shifter to the left through neutral to the left stop (and does not exert 40 lbs of pressure on what is a movement that should take ounces of pressure), then there shouldn't be an issue with the reduced horizontal distance in the SSK.
A driver can shift a SSK as slowly as he can shift an OEM shifter.
#45
Hi.
I have a 996 turbo and it came with a factory ssk. It was oem'd from B&M.
No tranny or other issues. Now, I had Dougherty Auto Sport in Philly (DAS, DAS bars...) rebuild the tranny due to the prior owner causing 2nd gear pop-out. In the process, the now famous mod was done to prevent this from happening and the mechanic, a chief mechanic for Rolex teams....., spent a lot of time adjusting the shifter. A lot. He explained to me that a huge number of issues can be simply due to the fact that adjusting the shifter is a major PITA.
With the new tranny, but before he had at it, shifting was notchy. With his work, it shifted "smooth as butter" and remains so.
-> You can get the B&M to shift wonderfully. It is very hard to do so. The good news: it has remained stable for 2 years and a lot of fun driving.
Jeff
Jeff
