If you've had a coolant coupling blow out with the accompanying near death experience
https://rennlist.com/forums/997-gt2-...-registry.html
This failure is only related to the GT1 blocks and therefore the TT's are included.
Basic Sponsor
2002 turbo, 85,000 miles - passenger side oil cooler manifold fitting blew out. Replaced with new factory part. The new part blew out on the drivers side less than one year (8,000 miles) later. Welded them both in place for a permanent fix.
991.2 GT3 RS Weissach Racing Yellow
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
former 1972 911T white, 1984 911 3.2 Targa black, 993 cab white, 993TT arena red, 993TT silver, 996TT speed yellow, 991.1 GT3 white
www.speedtechexhausts.com
info@speedtechexhausts.com
Testimonials SpeedTech Exhaust Videos facebook
2022 Cayenne White
Did you post in my other thread?
Location: Chicago - UMW Flash, UMW Performance Clutch (dual-mass), RUF exhaust, Evoms Bilit DV's,PSS10's, Pioneer Nav
This makes me paranoid about hauling around in my 996TT. The last thing I would want is a coolant hose letting go and the car to go veering off into who knows where. It's tempting to address the "glued" in fitting issue as well as replace all coolant hoses as preventative maintenance before they become problems.
What is the procedure for welding since one part is cast and the other part is extruded aluminum?
Basic Sponsor
Basic Sponsor
I don't think the fittings are aluminum. I am pretty sure they are stainless steel, as they are pretty strong and do not bend easily and they have to take a very tight clamp. I gave it to my welder and he did it. I seem to recall I said they were aluminum and he told me they were steel...they look like aluminum, though.
Basic Sponsor
I think he brazed it. My welder has a lot of experience and would have told me if the weld was a questionable situation...time will tell, I feel confident I'm all set now.
Basic Sponsor
Deputy,
Here are pictures of the welded fittings - doesn't look like it's going to pop out again...
Here is a picture of the first repair in process. Ugly and the reason I don't want to ever go there again...
