Stock Front Camber (max)???
#31
Hahahahaha!!!
Jon Send me the setup you use between the track and street... I want to "run a test" and see how tight tolerances are...
Mike
Mike
#32
Hi, Mike,
I'm in Switzerland now, until the end of May. My car and most of my notes are back in the States. I'm not 100% sure of what you are asking - alignment specs? Here's what I recall anyway:
Street alignment settings are GT2 spec. I think that is -1 deg camber and +1/16th total toe in front, and -0.9 deg camber and zero or maybe -1/16th total toe in the rear. I make the front toe with no shims in the GT3 control arm.
For the track, I add 14mm shims to the front control arm. That gives me about -2.5 deg camber. I adjust toe to same as stock, which is 10-10.5 turns on each tie rod end. For the rear, I adjust to -2.9 deg camber and same toe as street - whatever that is (it's in my notes).
I set the front PSS9 on 3, rear on 2. My sway bars are full soft in front, and 1 hole from full stiff in the rear.
There - you know all my setup secrets!
Jon
Jon
#34
Jon, Yup, I wanted to know how many turns you adjust the rears, and where you set the front and turn the adjusters for the toe!
TTSurgeon, Yup, Been running the GT3 split arms now for a while and I'm getting easily 3+ degrees negative camber on mine. We just swapped in the inner arm from ERP that has monoballs installed. I have installed the MODE upper mounts in the front as well... Have them for the rear, but hadn't installed them yet...
I think anyone would benefit from Rear Toelinks ($500-600), Rear Dogbones ($500-600), Front GT3 split arms/shim selection ($700) and call it done... A nice pair of GT3 or H/R sway bars and go have fun. Dell has a lift, is competent and can do most of this work himself, so the cost really isn't much... Less than $2K for sure...
During DE season, if Im' running a bunch of events close to each other, I'll set the suspension to my DE alignment specs and leave it. I drive it on the street with limited stints on my street tires. If it's going to be 2 months or more between events, I put it back to the stock camber/toe settings I run in the winter months. I do have the spec miata to fall back on if I get lazy and don't want to re-align the car.
Mike
Mike
#35
Mike
Mike
#36
