Stock Front Camber (max)???
Have the X73 suspension installed and am curious what the max neg camber that can be achieved up front in stock form (i.e., no 2 piece control arms, no slotting, etc)
TIA!
TIA!
Sincerely,
Macster.
Thanks Mac. It is actually at the dealer right now and the tech said he was able to get only just shy of 1 degree. I thought that was odd.
If one requires more camber then some adjustable factory steering/suspension hardware or even aftermarket may be required.
Now I don't believe this is the case, but I mention it for completeness, the amount of camber may be restricted cause of some -- and I just mention it because it is a possibility a slim slim possibility -- that the car has been in an accident and the chassis/tub not properly brought back into proper alignment and the repair shop used the suspension alignment to correct for this.
Ask the tech if the amount of camber possible is within his experience and knowledge and is consistent with other Turbos and even other modern Porsches.
Ask if the camber adjustment is all one way or the other which if so suggests alignment used in place of proper repairs.
Sincerely,
Macster.
The dealer tech was accurate. My x73 fitted car was just about, but not quite, 1 degree negative before installation of the two piece GT3 arms.
You'll also find that once fitted with GT3 arms, you'll need to do some slight modification (cutting away) to the inner fender liner to achieve more than about 2 degrees negative camber.
Here's all I could find. Turbo front camber preferred setting and allowable deviation for both USA and ROW suspensions.
Camber
USA 0 degrees ± 15 min.
RoW − 30 min. ± 15 min.
(max. difference left to right: 20 min.)
As you can see there's not much tolerance: +/- 15 minutes; so being able to move the camber adjustment to obtain 1 degree negative is actually quite impressive.
Sincerely,
Macster.
Camber
Sincerely,
Macster.
You should get between -1-1.2 camber in the fronts...
Dell, you know that there's a set of coil overs calling your name... Hahahahaha
Mike
Mike
Oh, and how about you guys quit guessing on this nonsense and download the factory service manual over on renntrack? Check the STICKIE in the 996TT section, Mkay????
Mike
Mike
Rickylandaverry (01-11-2020)
Bullshyte... I was running -1.5 camber on the fronts without pillowballs or GT3 control arms... All I had was PSS9s, GT2 ride height and nothing else...
Also, JICs come with addittional camber plates that will give even more adjustability.
And my shock towers were slotted from the factory...No way some hack made those holes/slots so perfect...
Mike
Mike
For all I know one might be able to crank the pupply over -3 degrees.
I note too the OP said the tech told him just shy of -1 degree was all that apparently was available.
Sincerely,
Macster.
Mac, I don't dispute what you posted, but I've been tracking these cars for over 3 years... I know what I know and nothing more... You have a cam adjuster in the lower control arm and the slotted upper shock mount. Both combined should allow for between -1.2 & -1.5 camber. Many techs won't pull the plastic and check to see if the uppers are slotted, because they don't know... It's as simple as them "not Knowing" and god forbid you tell them something they "don't know"...
Mike
Mike
