Garage Door Opener Hack/Mod
#76
I installed my garage door opener switches (I have 2 of them) in the overhead console (which you can only do if you have a coupe). The transmitter itself is Velcro-ed to a metal part above the overhead console (plus it's a tight squeeze there, so you could even do without the Velcro). I used two 1/2" diameter momentary switches (in shiny black matching the other factory switches) that I got from Radio Shack, back when there was a Radio Shack. Overall, it looks very factory-like and the switches are up high where you get the best range and where the manufacturer usually installs the Homelink switches.
#79
Forgive me, but I’m handicapped with electrical mods. I bought a keychain garage door opener and have programmed the big button for my porsche door. Works normal. I’ve ordered the Targa switch and the ashtray delete (I want to put the switch down there). I also have a community gate remote I was going to try to put on the other side of the switch.
Questions:
1. Can I tap power for switch lighting off the outer connectors of one of the window switches?
2. Can anyone tell me where to solder wires on the back of this fob? It’s different than the one in this thread (see pics). similar to the one in the Heidi/Franny vid...but not exact.
Thanks everyone!
Questions:
Thanks everyone!
#81
no need for any power source. use the battery from the door opener. push the buttons at the top pof the opener. the one the opens the door gets soldered to the targa switch. any post on the switch works. then tape it all up and slip it into the console under the ashtray delete.
Boss_Angeles (04-14-2024)
#82
Thanks man. Yeah, was definitely planning to use the battery for remote power, but was wondering about powering the Targa switch’s light (at night time). Also, just not sure what is what on the back of the circuit board (3rd pic posted). I think I have to solder a ground wire somewhere and then the other lead somewhere else.
I guess what I’m asking is where the heck do I solder the wires? thanks again!
#84
#86
My write-up and some pics. This is for a Chamberlain or Liftmaster keychain remote.
https://rennlist.com/forums/996-foru...l#post15089823
#87
I idle cool my turbos while sitting in my driveway, so while waiting I just open the center console lid, stick my finger in, and select the appropriate button on the remote.
#89
Did the garage door mod so my car has an OEM look garage door opener. Still don't understand why this doesn't come on the car but oh well.
What you need:
1 Targa Shade Switch #996 613 119 10 A05
1 Garage Door Opener
1 Soldering Kit
Crimps/Etc
Here's what I did.
1. Took apart my garage door opener to get the circuit board out
2. Located the button that activated the door (red button)
3. Flip board over and figure out which to two connection points activate the switch. You can figure this out easily by getting a paperclip, opening it up and then using both ends of the clip touch the contacts under the button (there are probably four). The two that activate the garage door (make sure you are near the door so you can see it activate) are your two connection points. Mark them with a sharpie or the such so you know which ones they are.
4. Solder a short pice of wire to one connection and another piece of wire to the other connection. I used 18 gauge wire.
5. At the end of one of the wires place a crimp on it and then insert two more wires into the other end of that crimp.
**Now you should have 3 exposed wires (one from one connection and two that were created out of the other connection)**
6. Place a female spade connection on all 3. I'd make sure and take your Targa switch with you to Radio Shack, etc, when you buy the spade connection so you get the right side that slides onto the posts on the back of the switch.
**If you want to make it light up then do step 7**
7. If you have heated seats (I'm sure you can use another switch for lights but I used heated seats) then you can tap into the + and - light terminals on one of your heated seat switched to make your new switch illuminate when you lights are on. To do this you need to tap the + (blue with red hash line) and - (brown) and run them to the two remaining posts on your targa shade switch. I have included the schematic so you know which post is + and which is -
8. After you have attached your 3 or 5 spade connectors test the unit for operation as well as lighting (if you did all 5).
9. If all works well, slide the circuit board in the cavity of the dash behind where the switch will go, attach the new switch to the center console trim (in a blank spot) and snap back on the console trim.
Voila! You have a garage door opening that looks OEM!
MAKE SURE YOU PUT A FRESH BATTERY IN THE OPENER SO YOU DON'T HAVE TO CHANGE IT FOR SOME TIME!!!
What you need:
1 Soldering Kit
Crimps/Etc
Here's what I did.
