Help w Offsets?
Help w Offsets?
I can buy RUF wheels,17", but don't know if they will fit my 2003 996 Turbo.
17 x 8, 20.4 mm
17 x 10, 4mm
Seller doesn't know. do these wheels use OE center caps?
HELP!
17 x 8, 20.4 mm
17 x 10, 4mm
HELP!
Those sound like the very early 911/930 offsets. Why would you run a 17" wheel. Most are on 18 or 19" for the 993/996 TT. I built a set of 3 piece wheels last year for 996 TT and used 6.5 inner and 1.75" on the front making a 8.5" front 18" wheel and in the rear used 7.75 inner and a 3.25" making a 11.25" wheel. They fit very well. The centers I used where Techart Daytonas which were made by Speedline. Most of these offsets that would would will be in the 40 - 45 ET front and ET 40 or so in the rear. Jim jdorociak@gmail.com
From my calculations those will not fit your car. With that low of an ET the wheels will be pushed too far outward even though they are sized 8 & 10's. Jim
