Another oil thread: Just changed the oil...
in my 03 Turbo, going from Mobil 1 0w-40 to Mobil 1 "high mileage" 10w-40 not because the Turbo has that many miles (just 17000 miles now and 4100 miles since last oil change) but because I wanted to see/feel/hear what if any difference a heavier "w" oil would have on the engine.
Too early to be sure, but the engine sounds quieter. Less clatter on startup and I believe the engine has a smoother idle as engine warms up a bit. When I first got the car I was a bit amazed at how out of tune (best I can describe it) the engine sounded upon startup.
By comparison, my 02 Boxster is much quieter at startup. Sure, the engine emits a bit of noise right at startup from a bit of cam chain dragging but the engine quiets down in just a second or three.
Really, the noise is very very brief. But even though cold the engine is smooth. (One co-worker compared the engine to a sewing machine it's so smooth.) Sure, the engine's running at a fast idle, but so's the Turbo engine.
Anyhow, the Turbo engine with this 10w-40 oil though only after just a few starts -- none from "cold" yet -- sounds much better. Tomorrow (Monday) morning after car sits overnight and will be at ambient temperature I'll get a chance to hear it from a colder start. Area in the beginning of a hot spell though, and night time temperature will probably be lucky to get in the low 60s at night though will climb with temps later in week forecast to be 100 during the day.
I'm going to run the 10w-40 oil until 20K miles then change over to Mobil 1 5w-50 and see what if any differences I notice. Might then stick with the 5w-50 oil but the 10w-40 oil seems to be a pretty good oil. And I use it in my 02 Boxster. 'course, I guess I could use 5w-50 oil in my Boxster. In fact next time I change its oil I'll use 5w-50 oil and note any differences, changes cause I have lots more experience starting the Boxster engine in all kinds of conditions.
Sincerely,
Macster.
Sincerely,
Macster.
10 weight for start-up is too thick...perhaps you should read up on what the dual weight system is...you don't want the cold oil weight (the first number) to be viscous as it prevents the oil from flowing where it should. I don't know why folks think sound is the way to judge the performance of oil. It isn't.
Another factor to consider is a 0w oil can flow away from oil spaces more readily than a heavier 5w or 10w oil and thus make a the 0w oil part of the problem a quicker flowing oil is intended to address.
Startup sounds is one way to judge an oil's behavior. Less sound upon startup is less wear and tear. The noise indicates more contact of a wear inducing nature taking place.
Sincerely,
Macster.
This is not clear from the owners manual. My 03 Turbo manual lists 0w and 5w 40 and 50 oils for temps generally higher than 50F and 0w and 5w-40 oils for temps generally lower than 50F.
However, underneath the chart it reads "... and viscosity grades of SAE 0w-40, 5w-40 or higher" which I interpreted to mean I could use either a 10w-40 or a 5w-50 oil as long as said oils also meet the stated API or ACEA classifictions listed by Porche and both Mobil 1 0w-40 and Mobil 1 10w-40 do that.
(Another document from Porsche -- an approved oils listing available from Micke Focke's pages -- does not list 10w-40 oil as being approved. However, IIRC and without taking the time to go down and fetch the owners manual to confirm my memory, 10w-40 and 15w-50 oils were approved for use in my 02 Boxster at one time and Porsche has since issued new approved oils lists that remove these oils.)
I'm going to run this oil until 20K miles (around 3K miles) and then switch over to 5w-50 oil and probably run with that year round.
Sincerely,
Macster.
Sincerely,
Macster.
I wouldn't assume that just because a certain weight oil is approved for the Boxster, that it would also work in the Turbo.
I like AE Haas' line of thinking when it comes to oil. But I won't go outside the boundary of what the owners manual recommends.
If you're going to play w/ oil outside the weights recommended by the owners manual, then you should definitely get oil analysis performed and start trending it.
///Michael
Read the Oil TSB for approved oils...and there are NO 10 weight oils on the list (if you need the TSB go to Renntech.org)...but hey it's your car...LOL
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
In any case, are you suggesting that if the car sounds quieter, that the oil is better?
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
