996 Turbo Forum 1999-2005
Need help with 997 SSK installation
Old 07-02-2009, 03:00 AM
isseps
isseps's Avatar
Default Need help with 997 SSK installation
I'm replacing the OEM shifter on my 2004 996 TT with a 997 SSK.
I removed the console. I had to remove the hand brake in order to get the console out. Is it neccessary?
How do I disconnect the 2 cables from the shifter box to remove it?
How do I connect the cables to the new ****er box to install it?
Thanks again guys...
Michael.
Old 07-02-2009, 09:56 AM
TT Gasman
TT Gasman's Avatar
You should not have to remove the hand brake. Go over to renntech.org there are a lot of detailed threads and diy info on the ssk.
Old 07-02-2009, 01:03 PM
Land Jet
Land Jet's Avatar
Do a search in this forum. There have been DIYs with pictures.
Old 07-02-2009, 09:30 PM
alex911s
Man of Many Porsches
alex911s's Avatar
You need to recline passenger seat all the way down, then pull the console towards that direction
Old 07-03-2009, 12:34 AM
Chuck Jones
Chuck Jones's Avatar
Some guys also use the B and M SSK instructions which are available online from B and M as a download instruction sheet. exact same methodology....different manufacturer.
Quick Reply: Need help with 997 SSK installation
