Vivid Racing - Clutch Masters New Release for the 911 Turbo!
Former Vendor
Clutch Masters 8.5" Twin Disc Clutch w/ Flywheel
for 996 & 997 Turbo
for 996 & 997 Turbo
It was only a matter of time before Clutch Masters built the ultimate clutch kit for the Porsche 996 and 997 Turbo. With the success of their Stage 3 OEM replacement kits holding 700 horsepower with daily driveability, Clutch Masters wanted to step up their clutch game and release this new 8.5 inch twin disk clutch with flywheel for the Porsche 911 Turbo.
The complete clutch weighs an astonishing 23lbs. The stock flywheel alone weighs about 40lbs! The lightweight flywheel helps improve turbo spool up by reducing rotational weight. As a kit, it is a complete bolt on for the factory clutch and flywheel. This kit is still a push style like the OEM unit. Other systems are a pull type which requires changing the factory clutch hydraulic system. All made in the USA, this clutch kit uses a combination of ceramic and Fiber Tough material to provide excellent driveability. The larger 8.5 inch disks provide a better engagement then the other systems currently on the market. These disks last much longer because of the material and sizing. If you are the type that likes to abuse your car on the road course or drag strip, these disks will last much longer then carbon ones. And if you still beat it up that bad, a complete rebuild kit with all the parts and hardware you need is only $995. Twin disks are generally used for those with high horsepower cars. With this clutch kit, we are talking almost 900 horsepower that it can withstand. Because of the use of precision engineered bearings and the larger diameter twin disks, the clutch relatively has NO chatter compared to those running a standard clutch and lightweight flywheel.
Clutch Masters has been testing these in the market on the much heavier Audi S4 cars with some running over 700 horsepower and almost 25,000 miles with great success. Vivid Racing also uses Clutch Masters on many of our Project Cars including our Porsche 997TT and Porsche 996TT. See More Info on our Clutch Masters Store Here.
Email, PM, IM, or call for pricing.
adam@vividracing.com
480.966.3040 x236
AIM: adam at vivid
480.966.3040 x236
AIM: adam at vivid
