996 Turbo Forum 1999-2005
door remote FOB not working
Old 04-14-2009 | 05:14 AM
jjrho's Avatar
jjrho
Default door remote FOB not working
hi, 03 x50 tip...53K miles...
just got it... one key works well as it should but the other key does not do anything even though the red LED lights.....no response from the car....
is there some sync procedure i can do? pls advise
james R
Old 04-14-2009 | 09:18 AM
Land Jet's Avatar
Land Jet
Could just be a weak battery. I'd try replacing that first, then talk to the dealer if need be.
Old 04-14-2009 | 10:30 AM
manny_g's Avatar
manny_g
need to get the electronics portion of the key replaced. takes about an hour at the dealer to program. ask me how i know...
Old 04-14-2009 | 11:06 AM
jimq's Avatar
jimq
Burgled
only took them 15 minutes to reprogram mine. Bring all your keys in because they need to do each one.
Old 04-14-2009 | 03:30 PM
jbossolo's Avatar
jbossolo
Sometimes if you haven't used the keyfob for a while, the battery losses it's juice. Try to put the key in the doorlock and turn it (I know, what a PITA, archaic, process!!!) it's supposed to "recharge" the battery or something. Sounds stupid, I know, but I've done it (after suggested by a fellow PCA member) and it works! Beats the bundle of money you'll be charged by the dealership!
Old 04-14-2009 | 04:45 PM
manny_g's Avatar
manny_g
is not that the battery looses its juice, is that the electronics need to be re-set and that is done by opening the door with the key. in this case the battery is fine, i.e. red led light flashes. his electronics does not operate accordingy. unfortunately needs new from dealer. do not think that no one except dealer can program the key.
Old 04-14-2009 | 08:36 PM
99firehawk's Avatar
99firehawk
keys are dealer only, have to get program codes from germany and use a pst2/piwis
Old 04-15-2009 | 04:06 AM
jjrho's Avatar
jjrho
Default key fob issue
well, i will try it...i did already open and lock the door with the bad fob key....
the alarm went off when i unlocked it with the key....after i locked it with the same key before goin into the restaurant....
the LED is bright as the other key fob...
it's too bad that it requires dealership involvement.....
i do have a 30d 50% labor off/50% part off 'warranty' from bev hills porsche....
i'd hate to drive all the way there....maybe riverside walter's porsche can do it....
well, i couldn't figure out how to change the battery either...i would put the batt from the other key and swap/and try but...if that resets the other fob too....
any other things to check?
j.rho
