Hood emblem came off!
Was giving the car a little rinse yesterday at a wand wash and when I sprayed the hood, the emblem flew off! I didn't even have the water jet that close to the car. So weird.
At any rate, better it happen there than on the highway.
So I'm left with an emblem that needs re-attaching. What is the best adhesive to use for this?
Epoxy? Silicone? Duct tape? chewing gum?...
Thanks in advance!
Thanks in advance!
Super Moderator
Needs More Cowbell
Needs More Cowbell
No adhesive is used.
You simply need to purchase 2 new 'press on speed nuts' which attach to the 2 bosses which are part of the hood emblem.
My guess is that at one point, someone removed the hood emblem and re-used them, rather than replace them.....they are (recommended) one time use items.
Super Moderator
Needs More Cowbell
Needs More Cowbell
Your dealer or Sunset Imports
http://www.sunsetimports.com/go/pinqry/
I'm sure there are other places as well.
Burgled
most any hardware store like HomeDepot would have them. You could also bend the tabs back down on the old ones and they might still work ok.
I lost a couple hood emblem on the track. saw it fly off like a leaf flying off my hood, gone bye bye... I found one and bending tabs wouldn't have worked as the post had broken off at the base of the emblem. bending posts would have weaken the posts even more.
I think that the actual posts have broken off. There are two little 'nubs' protruding on the hood and the emblem itself has nothing attached to it.
I'll take some pictures this afternoon and post them up so it's a bit more clear.
Does this mean that I have to get a new emblem?
Super Moderator
Needs More Cowbell
Needs More Cowbell
Yes.
Might be an opportunity to try and snag one of the 'getting harder to fnd thanks to Porsche and their lawyers' silver hood crests.
Super Moderator
Needs More Cowbell
Needs More Cowbell
The posts are no longer on my emblem - Not sure if they are built right in to the emblem itself (in which case they have snapped off) or if they're just epoxy'ed (in which case they have, er, snapped off, too).
When I get home from the office I'll post the pics I took this afternoon, but it looks like I'll need to get a whole new emblem.
