Clutch Slave Cylinder replacement help...
So I have my car up in the air have the accumulator off (Pentonsin sprayed everywhere, and yes I had pumped te pedal 25 times as recommended by the manual) and have loosened the bolts holding the slave to the tranny. I've gotten to the point of being ready to disconnect all three lines that go to the slave. Now I can't seem to disconnect the GREEN line from the brass connector that feeds the slave cylinder. Manual says to unscrew it, but I'm at a a loss... Any tips would be much appreciated...
Mike
Mike
