220 miles, 87 mph average and 28 MPG!
Chuck,
Yes in my case on my drive home with new car it was just 1200 miles of cruise control (and a few blasts
For the first 12 hours of the drive I barely saw 100 cars in either direction. It was the backwoods of Oregon and Northern California. I'll have to write a book sometime about my adventure. It was pretty fun and memorable.
I believe that, if you change injector size, the calculated fuel mileage display will be wrong. The ECU is commanding shorter fuel injector pulses (injector pulse = time period during which the injector is flowing fuel) during cruise with your larger injectors than it would with stock injectors. I believe it calculates fuel mileage by "adding up" the injector pulses. Larger injectors -> shorter pulses -> "better" fuel economy.
If you haven't changed cams or compression ratio, your cruising mpg should be very close to stock. It's fun to dream, though!
Jeff
Jeff
Basic Sponsor
991.2 GT3 RS Weissach Racing Yellow
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
former 1972 911T white, 1984 911 3.2 Targa black, 993 cab white, 993TT arena red, 993TT silver, 996TT speed yellow, 991.1 GT3 white
www.speedtechexhausts.com
info@speedtechexhausts.com
Testimonials SpeedTech Exhaust Videos facebook
2022 Cayenne White
Dennis: I know that at any time during a trip, you can reset your mpg function to zero and it will start over again at whatever rate of consumption is going on at the time....so you can actually get high mpg displays if you were to reset while on a long straight stretch and set it on cruise at say 70....but overall it will eventually drop down as you climb hills, go thru towns etc. In my 99 996 I did that reset function and got over 31 mpg for a stretch...but it was under absolute optimum circumstances while holding steady and already rolling at a given speed. I didn't even get that sort of mileage out of my motorcycle.
Some tuners out there can reprogam the ECU so the trip computer fuel mileage display remains accurate, even with large injectors, at least I know UMW can, but probably not many others in the USA. Good European tuners can do this too, I have friends running Sportec 600+ conversions and their actual gas mileage vs. trip computer displayed gas mileage is 100% accurate, even with VERY BIG injectors.
Just my 0.02.
Just my 0.02.
More around low 20s if calculated back to mpg when they drive the cars sensibly. 28 MPG at 87mph is definitely not feasible, next time you fill up, reset your daily mileage counter and when the tank is empty, check how many gallons you put in for how many miles, easy enough to work out MPG from there
Any up date here ?
I was shoping for an economy car for the wife, Mini Cooper was up on the list when I found this thread.
700 HP twin Turbo Porsche would be prefered
