Anyone remove the lower tension pulley?
I have a noisy pulley and will R&R it but the bolt won`t come out because it`s hitting the engine carrier. Does anyone know the best way to replace this?
thanks Mike
thanks Mike
Mike on the engine you have two idler pulley's located to the left and right of the tensioner (which has a pulley) If any of the two idler pulleys have failed you will need to remove your engine support which is alot easier to do when you have your exhaust pulled.
Thankyou Kevin, that is what I thought. I was going to send you my power steering reservois but the noise turned out to be the idler pulley.
PS I think everyone appreciates Kevin`s knowlege and his responses on this board! thanks again , Mike
I certainly am grateful for him being on here though.
