battery dead in 1 week?
Given replacement batteries are readily available for under $100, the high cost of replacing an alternator burned out from constantly charging a defective battery, and the hassle and loss of use of the car associated with a dead battery - I suggest everyone just replace their battery every 3 years or the first sign of it not cranking the motor over properly!
10 days is not normal for healthy battery.
Check to see if the engine compartment light goes out this is a common problem draining the battery quickly.
My point is still that there is a drain in his car or the battery would not go dead in one week.
I've not proven this yet but I believe the interior light on my car occasionally doesn't dim and shut down after the time delay (I went back in the garage one night and found it on).
I've toyed with various scenarios (closing the door with the car running in cool down, turn ignition off through open window ect) no dice to reproduce.
I just sidestepped the possibility by keeping the courtesy light in the off position.
(I visualize a whole bunch of p-car owners going to their cars to check)
Understood.... I just stated the fact that was told to me by a 53 year old senior tech at my a P car dealership. I agree there may be some other reason for the drain...
get the battery tested,
a freind of mine bought a new battery when he purchased a second hand 993. Still had lots of probs, spent lots trying to find problem - battery tested (faulty cell), got a replacement under warranty, problems still and found the replacement was also faulty - a bad batch came into NZ (hense 2 faulty in a row), so it does happen. symptoms were if car left for more than 2 or 3 days would not start - no other faults
